possible issue
im gonna guess its tuned in the ecu. So going under the hood and turning the knob is not really an option.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Yea WDC is what needs to get changed.
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
yeah my money is on colder weather... like 3gsucks said is it holding 22psi to redline or tapering down? if your wastegate was stuck open i would imagine it would hit more than 22psi. also like another said there is no magic boost level. It's all about where in the RPM band and under what load you are hitting the boost.
[/center]
[/center]
I do that well to often. Half read something then give my .02 cents.
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
scott tuned it for 20.5 tapering to 20. and its been perfect. it holds boost fine, np with that at all. and im fine with it being the cold air, i was just told anything over 21psi is pushing my luck, im right at 22. only reason i was worried. the car runs great. i wish there was a damn fix for my REALLY ANNOYING EBCS. my god, the damn thing ticks, and its loud. and i can hear it in my dreams now.
edit: yeah, opensource tune. no boost controller. i need to get a turbo timer. other than my gauges, i like a stock looking interior. i guess im gonna put the turbo timer in my center console, hook it to the e brake!
Coyote
Coyote
If you have a Tactrix cable I can e-mail you a map with more air-temp wastegaste compensation...
just e-mail me at siegelracing@gmail.com with what temperatures it's overshooting at and I'll e-mail you a map.
Siegel
Siegel
Scott
Forged Performance
www.forgedperformance.com
770-792-0202
Siegel Racing
404-388-8751
www.siegelracing.com
Driver / Engineer / Tuner / Instructor
Scott
Forged Performance
770-792-0202
Siegel Racing
404-388-8751
thanks scott, ill just take it easy on the car. im taking it to sr the thursday you are tuning, so you can just re-tune it for me, ill pay for it of course. thanks man.
Coyote
Coyote
550/550
SpecV did you reuse the rubber grommet to mount it?
Without it or "metal to metal" is loud.
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
