Subaru Tech All We'll Drive
Omg
Old Nov 24, 2008 | 12:40 PM
  #21 (permalink)
I'm Slow's Avatar
I'm Slow
damn, you have the worse luck with tranny's then anyone. Weird considering you are a "suby tranny guru"
Old Nov 24, 2008 | 01:04 PM
  #22 (permalink)
3gsucks's Avatar
Kyle you just like working out your left leg on that clutch.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Old Nov 24, 2008 | 02:02 PM
  #23 (permalink)
LDadrenaline's Avatar
yeah, I drive a miata
maybe a slight misalignment on the install? what shop did the work? you could sue them
[/center]
Old Nov 24, 2008 | 03:21 PM
  #24 (permalink)
FlybyTT's Avatar
dont think you can sue urself ?!?! maybe cuase i need a couple million
JDM STI V8 EJ207 - STI JDM 6 Spd spec c ra transmission - cusco rear lsd - catless turboback exhuast - IHI VF37 turbo - Walbro 255 fuel pump - HID lights - exedy clutch/flywheel
One Man's Trash Is Another Man's Treasure. (srqsti)
Working on the 3000GT VR4 in working order kinda...
Old Nov 24, 2008 | 06:43 PM
  #25 (permalink)
ryan_west06's Avatar
lmao, i did the install. every thing was TQ down to specs. dont see how you can misalign anything LMAO.
The only way i can see the throw out bearing bending like that is if the metal was to soft there. I talked to andrew today and he said that can only be the case. the fork can only pull the throw out bearing back evenly because it only pivots on the fork pin.
Old Nov 24, 2008 | 08:05 PM
  #26 (permalink)
racer_x's Avatar
vroom psshh.
^^exactly
Old Nov 24, 2008 | 09:09 PM
  #27 (permalink)
flystiguy01's Avatar
Skunk.
i would just get them to send you another throwout bearing. my guess is that it never fully seated onto the pressure plate for whatever reason and when you pushed the clutch it pulled and put pressure on one side of the ring and pop. i can honestly say that Frank's clutch and pressure are probably one of the greatest feeling and most gripping i've had the pleasure of testing. you'll be very happy once everything is sorted.
The thing I hate about an argument is that it always interrupts a discussion. -G. K. Chesterton
Old Nov 25, 2008 | 06:56 AM
  #28 (permalink)
but there is no way the clutch is rated for 600hp. The pressure plate is way to soft man. The disc may be capable. I sent everything back today, ill keep everyone updated on what happens. if they dont warranty the clutch im going to be pissed.
Old Nov 25, 2008 | 08:31 AM
  #29 (permalink)
Skunk.
i know what your saying about the pressure plate as frank's only felt a little stronger/harder than OEM. But I believe since they have such a grippy clutch surface that it does help. my personal rating of that clutch would definetly be down in my range of HP which is between 400-450. I have the exedy stage 2 3 puck clutch and flywheel, now THAT i'd rate at 500-600hp.. this pressure plate at a stoplight is HELL, my left leg is 2x the size of my right leg after a long drive through the city.
Old Nov 25, 2008 | 09:05 AM
  #30 (permalink)
lol....
