Subaru Tech All We'll Drive
Should I get it tuned ?????
Old Nov 10, 2008 | 08:00 PM
chevynut's Avatar
Mike ChevyNut
Default Should I get it tuned ?????
I just installed a Cobb header and full exhaust on my 1997 GT. I also have a K&N air filter.
I am NOT getting any CEL's
Should I get the ECU flashed to maximize my HP and what about mileage???
Should I install any other items (thermostat, intake spacers,etc...) before getting it tuned?
Thanks, Mike
Thanks, Mike
www.ChevyNut.com
1997 Subaru Legacy 2.5GT Wagon
70 Camaro RS/SS
Old Nov 10, 2008 | 08:39 PM
rex'03's Avatar
No need to as this is not a small block with a carb... Just my .02
'03 WRX 5-speed OBP (APS TBE, and Prodrive)
Snowmann Tune- 18 pounds
Old Nov 10, 2008 | 09:10 PM
LDadrenaline's Avatar
yeah, I drive a miata
why would you get a thermostat? if the car isnt overheating there is no need, and i highly doubt it is overheating. are there really any tunes out there for a 97 LGT? lol
[/center]
Old Nov 10, 2008 | 10:59 PM
flystiguy01's Avatar
Skunk.
no.
The thing I hate about an argument is that it always interrupts a discussion. -G. K. Chesterton
Old Nov 11, 2008 | 09:56 AM
skoloseven's Avatar
What about open source tuning? 3gsucks open source tuned my 02wrx and it was amazingly different. Sound, power, hp/tq curve, etc. I don't see why you couldn't OS tune the 97 gt unless the ECU doesn't allow it. (Like the old ecu's you must sodder chips on to)
If that's the case, maybe you can swap out your ECU for a newer one. This is getting over my head, i dont know if the ecu swap will work or not. Someone here does though i'm sure.
You might also try one of those intake sensor mods you find on ebay where you put a resistor in the AIT or MAF.. (Warning this is a guess).. I did this on my 99 monte carlo z34 which made it run rich. Then I changed the intake and free'd up the exhaust by removing cats, and it seemed to run pretty good compared to stock. My 99 z34 (not supercharged) would keep up with the 03 or 02 (not sure which first year for monte carlo s/c) off the line all the way up to gov cut at 105. I was actually a nose length in front of the s/c model, so there was power gain. I never dyno'd it, but butt dyno and track testing says it worked.
This is a subaru though, i dont know if you should go raping it like I did the chevy. Chevy can take it, i duno bout this. From what i hear, the tuning of a subaru is finicky, and you shouldn't mess with it like i did the chevy. But this is an older subaru, so it might work...
someone chime in that has more knowledge on my ideas if they'll help him out
Old Nov 11, 2008 | 12:26 PM
fail
[/center]
Old Nov 11, 2008 | 12:31 PM
blacksti's Avatar
DudeMan
fl gets hot a lot of people have different thermostats so the cars stays cooler... idk why you have to hate on the dude
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Nov 11, 2008 | 12:51 PM
the thermostat doesnt really keep the car any cooler though. all it does is drop the temperature about 10 degrees on the piston that lets the coolant flow through the radiator. even on a stock thermostat whenever it hits the temperature it starts cooling.
[/center]
Old Nov 11, 2008 | 02:25 PM
specVmatt's Avatar
400hp club, barely
10 degrees is better than... not 10 degrees?
Coyote
Old Nov 11, 2008 | 02:40 PM
it doesnt make the coolant 10 degrees cooler.... it just waits 10 degrees more before opening the thermostat to the radiator. The temperature at which the thermostat opens is FAR from being unsafe.
[/center]
