Subaru Tech All We'll Drive
Synchronic BOV
Old Sep 10, 2008 | 08:11 AM
ryan_west06's Avatar
Default Synchronic BOV
Ive been reading really good reviews on this BOV. How do you guys feel about it?
Dont flame me on a BOV, im very aware of running rich in between shift and blah blah....
Due to the fast reaction time on this unit. It seems to eliminate this problem....
I can get us a group buy discount if anyone wants one. Ill need 10 ppl
Old Sep 10, 2008 | 08:44 AM
blacksti's Avatar
DudeMan
told you it was good... ill be getting one soon fuck surge!
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Sep 10, 2008 | 08:45 AM
aznkrunk's Avatar
10 graphix= 500hp
I've heard mixed reviews about it. Most of the people think that you can get better bov's, but I'm not really sure. I would rather get a tial or something.
New setup in progress
Old Sep 10, 2008 | 08:47 AM
racer_x's Avatar
vroom psshh.
HKS SSQ-V is my first choice, but that doesn't mean that I won't consider this for my next project...
Old Sep 10, 2008 | 08:48 AM
i seen a video of the tial and this one side by side! The Synchronic is alot faster to react. I think ppl are stateing it wont hold higher boost settings.
Old Sep 10, 2008 | 08:49 AM
HKS is bobo
Old Sep 10, 2008 | 09:01 AM
LDadrenaline's Avatar
yeah, I drive a miata
what is defined as higher boost settings? 25+psi?
[/center]
Old Sep 10, 2008 | 09:06 AM
blacksti's Avatar
DudeMan
of course you can get better bov... like 80% of them leak even tial leaks under vacuum... the synapses bov eliminates compressor surge... for those of you who dont know what that is... its when the blades of the turbo are forced to spin backwards and it gives your bov the "flutter" noise which kills the turbo and gives you shaft play...
2jz mustang build
Old Sep 10, 2008 | 09:46 AM
-faded-'s Avatar
infraction king
i had the Tial and liked it much better than any bolt on BOV. car ran much cleaner and smoother.
98 E36 ///M3 Sedan
07 Civic Si Sedan
Old Sep 10, 2008 | 09:58 AM
Alizarin's Avatar
Gravel fiend
warning...
Not quite. They're not forced to spin backwards, it has to do with pressure waves coming back off the closed throttle plate and striking the compressor blades. Some of that pressurized air also passed back through the compressor and out the inlet of the turbo. This combination is what causes the dreaded "surge" noise. Sure, the compressor wheel slows down, but it won't reverse.
Or, think about it another way. You have the shaft with the turbine and compressor wheels spinning at almost 1667 revolutions per second (assuming 100k rpm which isn't a bad assumption at full bore, some turbos spin over 200k rpm). That's a whole mess of inertia to overcome to make it spin backwards in a fraction of a second. Which means a very large force is needed. I have a feeling if you do the math, you'll likely snap the shaft or totally destroy the blades before that happens. Not only that, but you still have exhaust passing through the turbine wheel, causing "forward" motion.
Also, ryan, you provide no links. The lazy among us won't search for it if you're going to shill it.
