Synchronic BOV
Really? Weird this guy has a Tial on his WRX and I dont hear any surge
YouTube - Synchronic BS Callout 2: Proper TiAL setup on Low Boost
To me it doesnt really matter, but to say that Tials or any other BOV surges is just improper setup honestly.
If your setup works for you, cool, but dont say that all Tials surge, or any other BOV for that matter, and that the synapse is a miracle cure for everyone. People have and still make their aftermarket BOVs work without surging.
Personally, unless you're running a blow through setup (I know you are) a recirculating valve will work better IMO.
theres no way a fast response BOV will eliminate the rich between shifts. If its letting the air out, then its not in the system. I don't think a "slow" bov is letting any new air go out so it will have almost zero effect on that problem. I'm not sure where you guys got that idea.
Little to no airflow+gas=rich.
-Winston Churchill
-Winston Churchill
Hey guys, this is Peter from Synapse, I am the one that designed the Synchronic BOV. I ran across this thread tooling around the internet. I'm only jumping on to chime in on the "rich between shifts" discussion, but I also want to address any concerns you have about doctored videos, etc. So, forgive me for the long post.
This isn't some random guy's video, this was made by Jake from Tial. Watch how the valve floats after discharge. That spring in there is way lighter than what they have in the instructions.
The Subaru in our videos was run in identical conditions. The Tial does blow, off, but only after a certain boost pressure, regardless of RPM. The point is that the Tial will flutter at anything below that boost pressure. Which, for reference is what you're doing daily driving anyhow. You aren't doing WOT full boost in every gear on the way to get Dunkin D.
Watch this video, you'll clearly hear the Tial discharge at full boost. You can also hear it surge after it discharges:
YouTube - Tial vs. Synchronic BOV
This video was cut shorter, since people have a short attention span:
YouTube - Synchronic BOV Subaru WRX
The fluttering sound you hear on the Synchronic revving at idle is the anti-stall flapping at low air flow rates, not compressor flutter.
Why does the Tial work this way? Because it is designed to stay shut at idle, not open up at all boost pressures. Why do you think that they have you match your vac level to a spring? The car was setup per their instructions. Bottom line, that same spring pre-load pressure needs to be overcome in order for the BOV to open up. So 11 psi spring, means that you're surging at anything below 5 psi. Why 5 and not 11 since it is an 11 psi spring? Because you have to factor in the vac pressure on the diaphragm + boost in the pipe pushing on the valve face = 5-7 psi. The Tial works as designed. You can run a lighter spring, but as many find, the performance and response is just not as good.
Now, regarding rich between shifts . . . I experienced a weird scenario the other day with our test Evo when doing more testing. We did vent to atmosphere without our anti-stall and didn't have any problems, but on a Subaru you will have problems because it runs differently. Now, the interesting thing is that we ran it in one configuration (Port A+B for vac) where the the BOV was open more at idle and it ran sloppy and ran like it had a leak past the MAF. But then we ran it in another configuration (Port B only) that didn't have the valve open so much, still VTA, and it ran with absolutely no problems. First and foremost, we recommend everyone recirculate on a MAF car, especially a Subaru. But, we're actually going to run this test next week ourselves too on a Suby.
All other BOVs on the market, based on the geometry I've seen, are all designed to just dump air flow upon opening. The Synchronic is actually designed as a flow regulator. So, for the engineering types, the valve position is different based on the level of vacuum, so it follows the changes in the intake manifold to the T. And flow rates are designed to be linear, with regards to valve lift relative to seat, assuming subsonic flow.
We'll let you know what we find with testing. Also, Tampa is far from Miami, but there is a dealer there NipponPower.com where you can go, try the bov, just to try it. This is how confident we are with the product.
I've done a few of them for customers. The machining seems top notch and The use of O-rings over diaphragms is cool, but in the end it's still a BOV.
As far as I'm concerned, if you're running a ball bearing turbo or one with a 360 degree thrust washer, you don't need a BOV. If you do run one, just have it recirculated and you will avoid these problems.
Whether you have a BOV or not, you're still snapping the throttle shut and cutting off your air between shifts (making it run rich).
BTTS, STFU&D
BTTS, STFU&D
mranlet- A couple of years ago I would've been on the same boat as you when it comes to BOVs. But after having many customers running them on their cars and coming back with all sorts of feedback, I've actually learned a few things.
As you know the Synchronic BOV is always open with vacuum. A pain in the ass right? Well one thing that many of our circuit racers started to tell us is that after the BOV was installed, the motor started to pull more vacuum. Well, since it is open under vac it will relieve pressure right before the throttle when the throttle is shut (when installed between the IC and throttle plate). This creates a greater pressure differential across the throttle under heavy vac and lets the engine pull more vac under decel.
How is this good? This allows the brake booster to have more vac under heavy braking and improves performance at the track for circuit racers.
So, sometimes there are side-effects that you don't even design in that come up with all the different applications that the product is used on.
I had all kinds of problems holding boost with most BOV that i owned. Once i changed to Tial i have never had any problems. My car has a MAF and i dont recirculate it and i never had any problems.
Scooby05
