Subaru Tech All We'll Drive
quick question
Old Jun 3, 2008 | 08:59 PM
randysti's Avatar
Default quick question
i just recently hit 50.000 miles, and was wondering what maintenance so i have to do to a 05 sti.
please if anyone can help me out, i would rather do it my self then have a dealer do it for me
i just need to know the main things. so far nothing is wrong with my car. just need to know what to do at 50.000 miles
thanks for helping
2008 Lexus ISF
2007 Aprilia RSV 1000R > Leo Vince full
Old Jun 3, 2008 | 09:03 PM
flystiguy01's Avatar
Skunk.
thanks for helping
there should be a maintenance schedule in your owners manual with all the intervals and such.... i'd pull it up for you but it would be just as fast to flip through the book.
The thing I hate about an argument is that it always interrupts a discussion. -G. K. Chesterton
Old Jun 4, 2008 | 06:24 PM
cpages2's Avatar
PWN5 J00
IIRC its 60K you need to worry about.
- Mike
Rally driving, when you're fertile enough to impregnate women with eye-contact
Old Jun 4, 2008 | 08:17 PM
Wrxgurl06's Avatar
- Mike
Yeah, this is what it says for 60k:
Recommended Inspection Fuel systems, lines and connections
Replace Fuel filter
Inspect Drive belt(s) [Except camshaft]
Inspect Camshaft drive belt
Replace Engine oil
Replace Engine oil filter
Replace engine coolant and inspect cooling system, hoses and connections
Replace Air cleaner element Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil)
Inspect Automatic transmission fluid Replace Brake fluid
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Inspect Brake linings and drums
Inspect brake lines and check operation of parking and service brake system
Inspect Clutch operation
Inspect Steering and suspension
Recommended Inspection Front and rear wheel bearing lubricant
Rotate and Inspect Tires
Replace Spark plugs Replace Spark plugs
-2006 Subaru WRX Limited
-2009 Chevrolet Cobalt SS
Old Jun 5, 2008 | 04:18 AM
xxBoost Junkiexx's Avatar
MPG FTW!
You are overdue for the 45,000 mile service:
Every fluid in the vehicle gets replaced besides the coolant.
Tire rotation and a major inspection.
