Subaru Tech All We'll Drive
Clutch install woes
Old May 22, 2008 | 08:04 PM
homemade wrx's Avatar
hold on...first put a 2x4 before jacking up the engine via oil pan...you can get plenty of pitch with the mounts still connected.
Also try twising the driveshaft when sliding the trans on...should slide on like butter.
I've had several hang up like you are describing and this is the first thing I check...always has worked.
Old May 23, 2008 | 07:51 AM
racer_x's Avatar
vroom psshh.
I will try... it is acting like one of the studs is bent, though. I'll keep everyone posted.... safe to jack on the oil pan even with a piece of wood?
Old May 23, 2008 | 08:39 AM
well, I've never jacked it up really...for me the car is usually on a lift and I use a screw jack with a 2x4 between it and the oil pan...spreading the load across the surface area. I then just pivot the engine (hence leave it bolted down) so that it tilts downward toward the tranny.
Old May 23, 2008 | 10:43 AM
ryan_west06's Avatar
you can jack up the engine a little, with the piece of wood. But dont do it to much. It will make the engine raise and tilt at a angle a little. Makes it much easier
Old May 23, 2008 | 05:37 PM
flystiguy01's Avatar
Skunk.
we finally got the engine and tranny to mate up. now we're having a hellova time getting the clutch fork pin in.... it goes in like halfway and then seems like its stuck and wont go any further. i dont understand wtf is happening, i made sure the clutch fork was properly inserted into the throwout bearing before getting everything back together... anyone had this problem?
edit: its going through the fork and getting stuck on the otherside. tried spraying it with some silicon to lube it to no avail...
The thing I hate about an argument is that it always interrupts a discussion. -G. K. Chesterton
Old May 23, 2008 | 06:43 PM
blacksti's Avatar
DudeMan
quite be pussies and push it through =)
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old May 23, 2008 | 08:30 PM
  #17 (permalink)
are you turning the pin? it has an alignment notch on it (slides in on the far side) to keep it from turning.
It would also be further than half way though.
Old May 23, 2008 | 09:39 PM
  #18 (permalink)
racer_x's Avatar
vroom psshh.
can't turn it... the damn thing came out very easily, so its reasonable to think that it should go in easily. any ideas other than this?
Old May 24, 2008 | 04:04 AM
  #19 (permalink)
Skunk.
got it peeps!
the solution: brute force.
Old May 24, 2008 | 06:41 AM
  #20 (permalink)
blacksti's Avatar
DudeMan
Originally Posted by flystiguy01
got it peeps!
hmmm wow like i said i to do
2jz mustang build
