Subaru Tech All We'll Drive
Do I?
Old Feb 8, 2008 | 06:59 AM
flystiguy01's Avatar
Skunk.
Originally Posted by homemade wrx
I'd just buy pistons, rods, new bearings and some headstuds...then have a machine shop do the work...you will use your same crank and block...it will cost the same or marginally more than a new shortblock but you will have a stronger motor...
BEFORE doing any of this...ask them where the leak was? you can check the crank case (rings), coolant jacket (headgasket) and/or valves (torched valved or valve seat)...
thats the thing man, they "think" the middle ring on piston #1 is bad... how can they know that without actually opening the motor? and how can they ask me to buy a new shortblock if they arent 100% sure that its needed?
im leaving right now to grab my car, thanks guys.
The thing I hate about an argument is that it always interrupts a discussion. -G. K. Chesterton
Old Feb 8, 2008 | 10:25 AM
homemade wrx's Avatar
you can get a stethoscope (spelling?) and listen for where the air is leaking out...they should know how to do it...also be sure they are diong all this testing on a warm/at operating temp motor with throttlebody open while crank...also having injectors unplugged.
If you want, you have my number, you can give me a ring.
Old Feb 8, 2008 | 04:50 PM
f85stealth's Avatar
Originally Posted by ryan_west06
I actually just got done reading a write up on pulling and installing a shortblock. It seems pretty easy if you have a weekend open. Id save the labor money and install it yourself. But you can buy a stock shortblock at mastro for $1900 (not sure on the price).
hahah seems pretty easy. Everything is easy in theory
Old Feb 8, 2008 | 04:51 PM
f85stealth's Avatar
let a pro do it pleaaassseeee
Old Feb 9, 2008 | 11:00 AM
racer_x's Avatar
vroom psshh.
hey chris, when you get back and read this, I have a friend who builds racing engines in town... full shop, good guy and will do it fairly cheaply. Call me at (941) 809-7633. Drive safe... I'm sorry to hear that's what it was! And... >.< you drove all the way to GA to do a compression test!?!?!?
