Subaru Tech All We'll Drive
Sti Turbo on a wrx
Old Jan 3, 2008 | 02:01 PM
ryan_west06's Avatar
PPG Transmission should be at the top of your check list with these running mods!
Old Jan 4, 2008 | 05:29 PM
homemade wrx's Avatar
what year wrx do you have? if you have a 2.5L the vf39 is still a bit small in my opinion but better than what you have now...if you have a 2.0L its good for the 11's with a good driver and supporting setup. The STi injectors are sidefeeds instead of top feeds though...the vf43 is a newer sti turbo that is a bit nicer too.
Old Jan 4, 2008 | 05:51 PM
JonLGT's Avatar
Just for decoration
Pinks are top feeds.
Old Jan 5, 2008 | 10:26 PM
ok, I think he is reffering to usdm sti's not jdm...or at least I was hence no comment on vf37 or vf30's which were accomodated by sti pinks which, yes are top feeds...the 07+ are top feed too IIRC
Old Jan 6, 2008 | 02:07 PM
shelsti's Avatar
https://www.tamparacing.com/forums/s...sti-parts.html
checkout my music at
http://www.myspace.com/singularismusic
my biz http://www.suncoastexpressinc.com
Old Jan 6, 2008 | 03:31 PM
0gravity's Avatar
so just the sti turbo and injectors or will it be better to just get the sti injectors also? Who is the best local tuner around here?
Old Jan 7, 2008 | 04:43 AM
  #17 (permalink)
1BDREX's Avatar
Jeff aka Snowman
99 Prelude SH-slow but sooo SEXY
04 WRX-300WHP silver bullet
09 Si SEDAN UNDER CONSTRUCTION
Old Jan 7, 2008 | 05:21 PM
  #18 (permalink)
bcs925's Avatar
to upgrade the turbo, shouldnt he upgrade the I/C too? or is that just optional/recommended?
WRX TR... Tampa Racing Edition... because its sure as hell not Tuner Ready
Old Jan 7, 2008 | 07:27 PM
  #19 (permalink)
its recommended but not needed unless he plans to go above 15 or so lbs...I would recommend it as it will always give more power through higher air density
