Subaru Tech All We'll Drive
another engine question
Old Nov 1, 2007 | 07:06 AM
homemade wrx's Avatar
don't forget with those new pistons going in, its best to not do drop in pistons...hope that the walls are scarred up too (most likely not).
I would go ahead and do a build on the shortblock while its out and needs to be torn down and checked out. It would be a shame to drop in pistons, install the motor and have a bearing that got scarred under impact of the accident or the valve and then have to do it all over again...I would buy some used sti heads for $600 and build those as well as the block...then slap in a nice complete longblock when everything is "done right" but then again my mentallity is "do it once, do it right".
the block year doesn't matter, it will fit.
a good port job on wrx heads get maxed at about 270-275 intake on my bench...sti heads demolish them once ported and deshrouded
Old Nov 1, 2007 | 08:09 AM
jblaine's Avatar
Comprehensive
I wouldn't buy it for $500 until I saw the piston tops.
You could be looking at:
$500 block
$400 new pistons
$xxx re-hone + piston swap work
In which case you'd be better off buying something else.
[ Stage Infinity ]
Old Nov 1, 2007 | 10:58 AM
you forgot about bearings too...but then you look at the cost of having a fresh, stronger block with better bearings for less than the cost of an oem sti shortblock, it isn't a bad investment at all...I would personally save up a bit more and do rods as well...Labor is the expensive part if you decide you want to go back into the block.
Old Nov 1, 2007 | 07:51 PM
boostnwrx's Avatar
ya but if there is nothing wrong with the piston tops then i have a sti block for 500 and later on i can put new pistons and junk in it have a brand new one so im gonna go ahead and get it thatns for all the advice ppl
Old Nov 1, 2007 | 08:10 PM
I say go for it...if the pistons appear find, the rest of the shortblock should be too.
Old Nov 10, 2007 | 08:34 AM
boostnwrx's Avatar
i got the block in great shape a couple of questions were can i get the head gasket and studs for the wrx head im putting on it for a decent price and do i need to get a sti ecu
Old Nov 10, 2007 | 09:07 AM
  #17 (permalink)
ryan_west06's Avatar
you can get gaskets at jscspeed i believe.... oh and try vividracing....
you do not need a sti ecu! just get a tune from jeff...
Old Nov 10, 2007 | 10:57 AM
  #18 (permalink)
I've got a set of brand new OEM STi gaskets for cheap that I got with my complete gasket set. I don't need them as I'm on some big bore cometics. For the head studs I would go ahead and pick up ARP studs while you are at it as they are minimally more than OEM cost.
Old Nov 11, 2007 | 09:32 AM
  #19 (permalink)
boostnwrx's Avatar
do i just buy wrx head gaskets cause vivid has some nice ones and what thickness will be better
Old Nov 11, 2007 | 06:25 PM
  #20 (permalink)
buy an sti gasket...the wrx gaskets bore is too small
what CR do you want to have in the end? you will be sitting 9.0-9.1:1 with and STi shortblock and wrx head
