need help/will pay!
I have an 06 sti, i recently installed a new turbo, tgv, fmic, inlet and injectors. ive hooked it up to my compressor and cant get it to hold more than 10 lbs. seems to be leaking from around the passenger side tgv/injectors. if there is someone knowledgable and experienced i will pay you to work on the car and get it ready. im just too buisy with work and school and tired or working on it myself. i understand the problem may not be an easy fix, so i will pay a minimum or say 75-100 for you trouble as long as you get the car back to where it was before you started. if you fix it i will pay at least 150-300 depending on time, it may be as simplae as taking off the intake mani and clamping/tightening something down, idk. if you would be interested please call josh at 863 860 5405. i live in winter haven, about 30 min west of orlando, 45 min east of tampa.
did you forget to put the orings in? because i lost mine and didnt know they needed them
afaik all the O rings are there, yes i seems to be leaking from around the injector, someone else was doing the injectors while i did other stuff. i know the o rings were on the drivers side. he deatschwerk had new small o rings on them, larger ones were reused, appeared fine.
so you did put the ones that came on it back on fuel rail right?
hmm im stumped then
