Subaru Tech All We'll Drive
tranny problem help
Old Oct 24, 2007 | 03:00 PM
xxBoost Junkiexx's Avatar
MPG FTW!
Puncuation is your friend, that gave me a headache just reading it.
Old Oct 24, 2007 | 04:36 PM
ryan_west06's Avatar
ok man! see this is were you need to listen to me closley.
DO NOT get a 4 puck! i recommend you get a stock clutch. If you end up getting a 4 puck you will put alot of stress on the stock gears. You will eventually blow your tranny! you said you do drive it hard.....
You will be in the same spot i am. dealing with a tranny that stripped 2nd and 3rd.
Old Oct 24, 2007 | 04:47 PM
MPG FTW!
But then he'll get to dogbox :devil:
Old Oct 24, 2007 | 04:49 PM
blacksti's Avatar
DudeMan
im gonna get a meow box.... tap a cat in a box to the front of the car the faster you go the louder the meow
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Oct 24, 2007 | 04:54 PM
homemade wrx's Avatar
if he does NEED a strong clutch, I would recommend a full face organic or full face kevlar...pucks are bad on a stock tranny as the shock load from ingaging (very littel slipping) causes gear failure.
-Micah
Old Oct 24, 2007 | 04:59 PM
LDadrenaline's Avatar
yeah, I drive a miata
lol
[/center]
