Subaru Tech All We'll Drive
Turbo swap, what else do i need?
Old Aug 9, 2007 | 09:14 AM
13Brotary's Avatar
Default Turbo swap, what else do i need?
I'm swapping out my stock turbo for another stock turbo this weekend and was wondering what other parts I am going to need other than uppipe and downpipe to turbo gaskets. Also, does anyone have any tips or tricks?
Old Aug 9, 2007 | 09:22 AM
sonicwrx's Avatar
from personal experances i would spray the dp nuts with pb blaster or wd-40 before cranking on them i had a nut locked on and broke a stud the first time i took my turbo off
Old Aug 9, 2007 | 09:28 AM
homemade wrx's Avatar
you have all the parts you need...as suggested, definately put some pb blaster on there a bit ahead of time and let it soak in. stripping a stud will ruin your day
Old Aug 9, 2007 | 09:53 AM
ImportImageRacing's Avatar
Subaru/Evo Parts Hookup!
a set of the sti nipples from 2 posts above?
Rides-
2012 GTR
2011 WRX
2009 GTR
www.IMPORTIMAGERACING.COM
With over $10million sold, 30,000+ happy customers, over 100 brands to chose from, at the best pricing...best customer service...No wonder so many choose Import Image!
Old Aug 9, 2007 | 10:00 AM
13Brotary's Avatar
thanks guys, im really worried about snapping a stud. i think im going to spray them the night before as well just to let them soak overnight.
Old Aug 9, 2007 | 10:34 AM
sonicwrx's Avatar
u should be fine its not a hard project. when u get finished take the car for a drive, make good boost and check for any unusual noises, if the uppipe gasket leakes it will make a distinct noise and you will have to tighten it. uppipe leakes are bad.
Old Aug 9, 2007 | 10:47 AM
one thing a lot of people screw up and thus toast the motor is getting the oil drain line back on...
BE SURE that the return line is on that rubber hose!!
It really isn't bad at all...just time consuming
Old Aug 9, 2007 | 11:47 AM
I'm Slow's Avatar
I'm Slow
If you need someone to do the work for you, then pm me and lmk. I am very reasonable.
Old Aug 9, 2007 | 01:20 PM
Alizarin's Avatar
Gravel fiend
Also, inspect the condition of the brass washer that goes on the turbo oil feed banjo bolt. And don't lose said washer. Oh, and have some coolant around, because you'll lose some out of the coolant lines when you take them off and put them on the new turbo. Also depends on how well you can plug it up while they're disconnected.
Torque specs for the exhaust bolts are about 26ft-lbs. Oil feed line banjo bolt torque spec is 11.6ft-lbs according to service manual.
Old Aug 9, 2007 | 03:43 PM
mike06wrx's Avatar
And about the oil dump just put some oil on the dump tube and it will slide right in
