Subaru Tech All We'll Drive
Omfg
Old Mar 1, 2007 | 07:03 AM
FlybyTT's Avatar
Default Omfg
tranny is in but its not working properly its not letting me shift into gears if the cars at idle i can go up thru the gears but cant downshift them like the clutch isnt fully depressed or the release bearing releasing here ans example im in 1st after i turned the car off start the car as soon as my foot is off the brakewith the clutch fully depressed the car will begin to roll any1 have any ideas ima bout to go nuts
thanks Ryan
JDM STI V8 EJ207 - STI JDM 6 Spd spec c ra transmission - cusco rear lsd - catless turboback exhuast - IHI VF37 turbo - Walbro 255 fuel pump - HID lights - exedy clutch/flywheel
One Man's Trash Is Another Man's Treasure. (srqsti)
Working on the 3000GT VR4 in working order kinda...
Old Mar 1, 2007 | 08:05 AM
Apexi wrx's Avatar
The NExt Brian O' Conner
Wow No clue but good luck you paid some bills
Vroommm psshhh
Old Mar 1, 2007 | 08:55 AM
stiscooby's Avatar
mech engineer
you might have tightened the flywheel to the clutch? i dont know good luck. i would try callin a few shops
-Matt
Old Mar 1, 2007 | 11:21 AM
Alizarin's Avatar
Gravel fiend
It sounds like the clutch isn't fully disengaging and you need to adjust the clutch pedal travel. There should be some lock nuts on the pedal that can adjust the stroke. If that helps but you run out of travel, service manual says to adjust the pushrod on the clutch master cylinder.
Old Mar 1, 2007 | 04:16 PM
fat angel's Avatar
Secret Squirrel
what shifter fork did you use? and what clutch(as in wrx or sti)?
Old Mar 1, 2007 | 05:21 PM
FlybyTT's Avatar
i have the sti short throw and the sti clutch
Old Mar 1, 2007 | 05:32 PM
fat angel's Avatar
Secret Squirrel
sorry i meant are you using an sti clutch fork?
Old Mar 1, 2007 | 05:34 PM
FlybyTT's Avatar
not sure good question
Old Mar 1, 2007 | 05:38 PM
fat angel's Avatar
Secret Squirrel
did the trans come with one in it? did you install the trans?
Old Mar 1, 2007 | 05:44 PM
FlybyTT's Avatar
i unfortunatly had aamco
