Subaru Tech All We'll Drive
Omfg
Old Mar 1, 2007 | 05:56 PM
fat angel's Avatar
Secret Squirrel
i'm just thinking that it almost sounds like it the new trans might not have had the clutch fork and the used the one from your 5speed. from the way you explained what's wrong that is what it sounds like.
even if that isn't the case they need to take that thing apart again because something isn't right.
Old Mar 1, 2007 | 06:01 PM
FlybyTT's Avatar
lol yea im goin back without a doubt ill get some more info for ya i def appriciaste the help so far
JDM STI V8 EJ207 - STI JDM 6 Spd spec c ra transmission - cusco rear lsd - catless turboback exhuast - IHI VF37 turbo - Walbro 255 fuel pump - HID lights - exedy clutch/flywheel
One Man's Trash Is Another Man's Treasure. (srqsti)
Working on the 3000GT VR4 in working order kinda...
Old Mar 1, 2007 | 08:40 PM
02'subie dude's Avatar
There is a possibility that they put the clutch on backwards, as difficult as that is, also you may just have air in the lines. I would bleed the slave cylinder first, and of course make sure that you did not use cheap tranny fluid. Are you getting any clutch pedal tension? When I installed my clutch I was stumped, because I couldnt put it in gear. Come to find out the fluid just needed to warm up. Definately take it back. Good luck.
Old Mar 2, 2007 | 09:25 AM
FlybyTT's Avatar
i tried the clutch adjuster nothing helped there they said "" they bleed it twice.... my ass but i heard it might be the input shaft or the pressure plate is dead... i have no idea but it shall be brought back
