Subaru Tech All We'll Drive
Help With Maf Problem!
Old Jan 28, 2007 | 08:28 AM
blacksleeper's Avatar
Giggity Giggity Gone
Question Help With Maf Problem!
Ok so here is the problem. I have installed a vf30, ebay tmic and all supporting mods. After installing everything snowman tuned my car to run 19psi peak and taper off to about 16.5-17 at redline. The car made full boost and had a perfect a/f ratio. The only problem is that the maf sensor was only reading a max of 230 g/s. Since then I bought a used maf with only 30,000 miles that worked perfectly, to replace my maf which I thought was bad. We hooked it up again today and it did a little better but topped out at 240 g/s. We even bumbped it up another psi and it still only hit 240 g/s. We can not figure out if it's the maf that is reading low, or if the turbo is actually not pulling enough air. Could it be that I need a cold air, or is my turbo not flowing what it should? Anyone have any ideas, at this point I can't figure it out? This turbo should be flowing at least 260 g/s.
Old Jan 28, 2007 | 08:44 AM
xxBoost Junkiexx's Avatar
MPG FTW!
Hmmmm somethin's up.
Old Jan 28, 2007 | 08:53 AM
I read on some other posts about scaling the maf. I didn't think I needed to do that cause I still have the stock inlet and air box. This is really frustrating.
Old Jan 28, 2007 | 09:59 AM
MPG FTW!
Have you visually inspected it? Maybe it neeeds a cleaning. Or you my just need a brand new one.
Old Jan 28, 2007 | 10:35 AM
RonnieMack's Avatar
Didn't you send that turbo to Deadbolt for inspection and such? They didn't report any problems to you, did they? Maybe it's the tune?
Old Jan 28, 2007 | 11:00 AM
RonnieMack's Avatar
Try borrowing someone's SRI and see if that helps.....
Old Jan 28, 2007 | 11:23 AM
djerickd's Avatar
CHILLING SPREE!!!
I got an Aprexi SRI for sale
SnowMan Tuned
Old Jan 28, 2007 | 11:33 AM
RonnieMack's Avatar
Aprexi??? Never heard of it!
Old Jan 28, 2007 | 12:13 PM
Apexi wrx's Avatar
The NExt Brian O' Conner
Make sure the inlet is to the turbo is not ripped a little rip in that could cause that
Vroommm psshhh
Old Jan 28, 2007 | 12:16 PM
fat angel's Avatar
Secret Squirrel
it is a rather interesting problem. realistically a stock box and filter should be able to flow it, but i would think about trying another intake. along with that check all your intake fittings and along the inlet( also where the inlet connects to the turbo). it's either pulling air from somewhere or not enough.
edit: apexi beat me to it, i took my time typing
