Subaru Tech All We'll Drive
Help With Maf Problem!
Old Jan 28, 2007 | 12:29 PM
blacksleeper's Avatar
Giggity Giggity Gone
i think it might be the inlet pipe....i noticed it looked a little worn so there may be a small tear somewhere where it connects to the turbo. it there was a tear would it still be able to hit target boost?
Old Jan 28, 2007 | 12:31 PM
other than that deadbolt said my turbo was in mint condition for it being used. and the turbo even has a new center cartridge and seals. so i am putting my money on a leak.
does anyone want to let me use one of their home made pressure testers?
Old Jan 28, 2007 | 12:33 PM
oh and both maf's have been cleaned with special cleaner so i know they are not dirty.
Old Jan 28, 2007 | 12:56 PM
fat angel's Avatar
Secret Squirrel
pretty much yes. it's just pulling unmetered air after the maf. you aren't too far off so more than likely i would check for tears/rips along the inlet first visually. then pressure check it, i have a tester you can use.
Old Jan 28, 2007 | 01:06 PM
on that note if i need one does anyone have a turbo inlet for sale?
Old Jan 28, 2007 | 01:11 PM
Apexi wrx's Avatar
The NExt Brian O' Conner
The stock ones are crap it is very common for them to rip with out really knowing
Vroommm psshhh
Old Jan 28, 2007 | 01:20 PM
  #17 (permalink)
thanks for the help....i hope that is the problem...i'm pretty sure it is. we'll see if i can find an aftermarket one to replace it with and see if that fixes it.
Old Jan 28, 2007 | 07:47 PM
  #18 (permalink)
djerickd's Avatar
CHILLING SPREE!!!
Originally Posted by RonnieMack
Aprexi??? Never heard of it!
it's the best see:
http://www.mkiv.com/techarticles/filters_test/2/
SnowMan Tuned
Old Jan 28, 2007 | 09:16 PM
  #19 (permalink)
3gsucks's Avatar
if there is a tear in the inlet you should get that fixed asap and not drive too hard as in keep out of boost (i know its a hard thing to do).
a leak between maf and turbo is going to cause a serious lean condition. Although if you were tuned with the leak you maybe ok.
I personally would just take it easy till you can check it out.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Old Jan 29, 2007 | 02:09 AM
  #20 (permalink)
RonnieMack's Avatar
Originally Posted by djerickd
it's the best see:
OOHH.. ApEXI.. .not ApRexi
Gotcha
