gizmo launch control
i could see that happening...
the sti's 6 speed is tricky...
evo 5 speed is more ummm mechanical in feel...its pretty damn hard to mis shift
its real easy to miss 3rd or 4th on the sti...even good drivers miss.
Rides-
2012 GTR
2011 WRX
2009 GTR
www.IMPORTIMAGERACING.COM
With over $10million sold, 30,000+ happy customers, over 100 brands to chose from, at the best pricing...best customer service...No wonder so many choose Import Image!
Rides-
2012 GTR
2011 WRX
2009 GTR
another thing is if you use the enginuity setup, you can get it for free
Stationary rev limit discussion
flat foot shifting= unhappy syncros
how exactly can ignition cut cause detonation and fuel cut not? i would think fuel cut would cause detonation (no fuel = lean?). I always went by the idea that ignition cut speed limiter was better then fuel cut, so how is this different?
plus it looks like its only ignition cut
The ignition cut is clutch activated allowing flat changing (the ability to change gear without removing your foot from the throttle).
Interface for 1-6 coil application
no fuel = only air. you can't have detonation without fuel, because air does not ignite.
edit: it is a caused lean condition.
good reading:
Launch Control - NASIOC
oh yeah and THIS:
Dual Stage Launch Control / Gizzmo Electronics - NASIOC
more encouraging words:
Launch control - ign or fuel cut? - NASIOC
good reading:
oh yeah and THIS:
Its going to be awhile (maybe 2 updates) before Enginuity releases this feature.
