some runs
Trust me Kyles car pulls hard. IIRC: loads peaked at 3.81 (or 3.86) and held to right around 3.00 just shy of 6k rpm.
For reference. S2 STi's generally see 3.1-3.2 peak
ps. I guarantee he was spraying as soon as he got out of the hole.
yea i thought my car was gonna pull harder afetr the meth.. i think that im gonna order a green in a few weeks
Guest
Posts: n/a
Not really hard to believe when you think about it. The mustang didnt start pulling until Kyle shifted to 5th (while the Mustang held gear with the gas just a spraying)...up until then the Mustang was just creeping.
i know jeffs car which is the same setup as yours pulled even harder up top. once he got into the longer gears, it just kept pulling. hes only running 21psi.
blacksti- what are your shift points?
i shifted a little before 6
with his mods, he should have still held his own better. i ran a sprayed mach1 at only 18psi with the green, mid tune/car running like ass with SS driving, 3 people in car, -7 degrees timing, car leaning out, the air on, and he still could not pull on me. we started to walk away from him up top.
Kyle, if you're unhappy give me a call..
[/unsubscribe]
Guest
Posts: n/a
thanks faded
