Cams or N2O?
well if you plan on doing road racing i would suggest a aqua mist water injection or 50/50 set up. you can tune it to make more power with the injection. or make the same amount of power but have you motor work 15-20% less.
the way i see it. if your going to do head work, or any thing with the heads. do it all at once. sine you have the motor out anyway. you would loose a little on the left side of the band, but the right side wouls see a vast improvment. so the left side really doesnt matter on the track in a road race.
NO2.... personally it is a scary choice. it is the easy way to make power.
