Subaru Tech All We'll Drive
Djerikd needs to make a writeup.
Old Aug 9, 2006 | 06:52 AM
JonLGT's Avatar
Just for decoration
Default Djerikd needs to make a writeup.
for the intercooler water sprayer. I have been looking for some kits online but if you could make a nice writeup I would appreciate it.
Old Aug 9, 2006 | 07:02 AM
xxBoost Junkiexx's Avatar
MPG FTW!
What's in it for him? wink wink
Old Aug 9, 2006 | 07:36 AM
3gsucks's Avatar
This is a good one for how to put one in:
ScoobyMods - Intercooler (IC) water spray system.
and this one
STi intercooler sprayer - ClubWRX Forum
i have not tried to build one yet but I may try
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Old Aug 9, 2006 | 07:39 AM
JonLGT's Avatar
Just for decoration
You can give him your signature move.
Old Aug 9, 2006 | 07:42 AM
blacksleeper's Avatar
Giggity Giggity Gone
i can show him how to make one from the existing windshield washers like i did. i never used my windshield washers and rigged it so that i can manually control a sprayer using the factory pump and tank. costs me less than 5-6 bucks to make the whole thing.
Old Aug 9, 2006 | 11:20 AM
djerickd's Avatar
CHILLING SPREE!!!
Those links are good as a guide.
What you really need essentially is a place to hold the water, a pump to push it, a nozzle or 2 to distribute in a mist, and a switch to contol it.
Tank - I have a coolant return tank mounted in my trunk
Pump - I have a windshield washer pump mounted directly on the tank with self tapping screws and silicone to seal.
Switch - I have a cheap momentary switch on my dash to turn on the pump as needed.
Lines - cheap plastic line I think it's 3/8" ID (look for what fits the pump and get enough to reach)
wires - to ground the pump and run the 12+
You can make any trigger your "switch" it's up to you how eleborate you want to get. For instance mine only works with the ignition on since it gets 12+ from the ignition.
It's really up to you how you want the system to function, it's just a basic water pump. I actually rarely use it and will probably install watergun nozzles aimed outward to spray people as I drive by.
I was going to use these same concepts to build my own meth/water injection kit (basically the same concept, to pump a fluid from a tank) but I picked up a sweet Aquamist sponsorship - more details to come...
djerickd's Avatar
CHILLING SPREE!!!
Oh hell no! I don't want that!
Old Aug 9, 2006 | 03:48 PM
my setup is not as cheap as it sounds
Old Aug 9, 2006 | 06:02 PM
djerickd's Avatar
CHILLING SPREE!!!
$5-6 sounds reasonable to me...
Old Sep 17, 2006 | 01:38 PM
djerickd's Avatar
CHILLING SPREE!!!
Log In
SnowMan Tuned
