i have no gears!
Guest
Posts: n/a
i have no gears!
the STi gears are so damn short and with the amount of mods i have its crazy how short they are now. i feel like im shifting like every 10 feet until i get to 4th
anyone have any ideas for longer gears? is there a company out there that sells a longer final dive? is it best to change to a 5spd tranny and have it built? i know my car would be so much faster if i had longer gears.
I wound not change to a 5spd. You would have to change the gears to be able to handle your power level. I just upgraded to a set of Kaaz gears in my 5spd. 1st is longer but everything else is so close and short. I am doing 3750 rpms on the highway for 70mph. I wish I had a 6th gear! Thank goodness I am still getting 24miles to the gallon!
Originally Posted by fadedSTi
if i were to trade for a 5 speed, it would have to be a built one
is it just an straight swap?
sometimes it sucks to be an sti owner.
Originally Posted by fat angel
no, you don't want to do it. unless it's a ppg straight cut setup. then do it. that should be your only trade. and then it's not a straight swap.
You will need a different drive shaft I believe and possibly rear end depending on the tranny you go with. My Kaaz is a straight cut 1-3 gear and is best suited for the 3.9 rear end. Nice and loud!
[QUOTE=weverb]Yeaa right! Like it really sucks to be a STI owner. Try owning a WRX. You always have to look up to the STI.
i am fortunate for what i have but id have to agree 100%. every day i wake up i think i couldve had an Sti if only i paid more monthly and saved more...but now im stuck with my 06 wrx.
ahh nvm, you have an 05, its a PITA to swap.
i think your kinda SOL on the 5-speed and i know nothing of gear ratios for the 06. i think PPG makes 1st and 2nd for the 6speed, but idk if the ratios are any different.
Guest
Posts: n/a
