Subaru Tech All We'll Drive
I suck!!!
Old May 4, 2006 | 09:35 PM
  #21 (permalink)
fresh&clean's Avatar
I love Lamp
Originally Posted by Krash114
with a 265 tire on an STi you beter have about 700whp.
Bwahahaha 699 my rims are really wide and arent made for Subarus.
Old May 5, 2006 | 03:18 AM
  #23 (permalink)
mantra1's Avatar
Shaggin' Wagon IV
That ARC induction box is killing you!!! Unless your tuned for more air, the maf will pull timing big time, especially at higher rpms. Put your stocker back on, reset your ecu and gain another 3-5mph in your trap speed.
Old May 5, 2006 | 03:19 AM
  #24 (permalink)
JonLGT's Avatar
Just for decoration
Originally Posted by Scoobaru
yea Im thinking about parting ways with them but everyone likes them and tells me to keep them. Decisions, decisions, decisions.
Functionality>Looks
Old May 5, 2006 | 05:34 AM
  #25 (permalink)
stiscooby's Avatar
mech engineer
like everyone has been saying. make sure you shift earlier. i have my light set aroun 6300-6400. makes a huge difference. My car is tuned all the way out to 7, but it is not worth it just b/c i get that feeling the car just gives out. Also, its probably the wheels. i would definitly try to find something lighter.
-Matt
Old May 5, 2006 | 06:33 AM
  #26 (permalink)
Krash114's Avatar
shifting earlyer is going to help, and it is the wheels. But its not the waight of the wheels because his 19's are 2lbs. lighter then the stock 17's. the problem is the circumference of the 19's as apposed to the 17's.
Old May 5, 2006 | 07:37 AM
  #27 (permalink)
DubtecV2's Avatar
...in da hause!!!
Overall diameter aside, even though your 19" wheels are lighter than that stock 17" wheels, the weight is further out from the center axis. Try taking a 20lb weight and spinning it. Then take that same weight, put it on a 5ft pole and try to spin it again. It's a lot harder.....
And, like everyone has stated, your tires are WAY too big! The stock 225/45-17 tires have an overall diameter of 24.97". Your 265/40-19 tires have an overall diameter of 27.34" - that's a difference of 2.37"!!
Let's say your speedometer reads 60mph with stock size tires. With the tires you have now it would read 54.7mph, even though you're still at the same speed. Now you speedometer is 5.3mph off, not uncluding how for it's off stock (which is normally ~4mph at that speed). You're almost 10mph off now!
When changing tire size, it's recommended that you stay within 3% of the diameter of stock tires. Your tires are 8.67% larger
If you like your 19's try buying tires that are 245/30-19. These tires have an overall diameter of 24.78", which is just slightly smaller that stock (difference of 0.77%). At 60mph, your speedometer would read 60.4mph.
Old May 5, 2006 | 08:16 AM
  #28 (permalink)
mofugga's Avatar
who stole my intercooler?
the wheels might be 2lbs lighter than stock but how much heavier are the tires in comparison to the stockers? doesn't seem like too bad a time with the hugeass tires though
Old May 5, 2006 | 08:22 AM
  #29 (permalink)
BrewPuBeaver's Avatar
*Big Schpellar*
Originally Posted by DubtecV2
Overall diameter aside, even though your 19" wheels are lighter than that stock 17" wheels, the weight is further out from the center axis. Try taking a 20lb weight and spinning it. Then take that same weight, put it on a 5ft pole and try to spin it again. It's a lot harder......
the idea is sound, but it doesnt aply...
if the tires were OFF the ground, yes. but since they are on the ground it takes the same amount of force to make them roll, but there is more stress on the axles...
Old May 5, 2006 | 08:26 AM
  #30 (permalink)
I love Lamp
Yea I have a feeling it might be my induction box thats why I have no top end. Im gonna try to find a stock Sti intake and go from there.
