Subaru Tech All We'll Drive
boost leak problem
Old Apr 17, 2006 | 01:32 PM
blacksleeper's Avatar
Giggity Giggity Gone
Default boost leak problem
I recently change by bov this morning from my stocker back to the hks ssq. made sure everything was nice and tight, but the problem is after driving it i am now only hitting peak at 16.5 then back to 13(redline) when before i was hitting 18-19 then back to 14-15. is it possible for the gasket to be worn out enough to leak 2psi off my top end? or is there another leak spot i can check? i asked ss and he said it might be the gasket, but i just wanted to see if anyone else had this problem before. thanks.
Old Apr 17, 2006 | 02:29 PM
nope its the original one from 2003......its probably the gasket, which i am replacing tomorrow, but i just wanted to see if there could be anything else wrong.
Old Apr 17, 2006 | 02:38 PM
byerly0137's Avatar
its probably the hks bov, you should just give it to me hahaha. jk dude
Old Apr 17, 2006 | 03:27 PM
thats what i get for changing my mind .....changed the bov 1 to many times and now the gasket is blown. it needed to be replaced anyways.
Old Apr 18, 2006 | 08:11 AM
$5.88....just picked it up, and now im waiting for the engine to cool down a bit. we'll see what happens in a couple hours when i test it out.
Old Apr 19, 2006 | 04:05 PM
fat angel's Avatar
Secret Squirrel
if that's not it you can test leaks a few ways. vacuum with something like carb cleaner( engine will rev a little higher), boost w/soapy water(bubbles), boost leak tester( pump in 20 psi and look for leaks).
also i don't know the hks bov but it could be it itself.
