Subaru Tech All We'll Drive
OK, WTF is up with this?
Old Feb 5, 2006 | 07:08 AM
Franklin's Avatar
Not all cars have that problem.
Old Feb 5, 2006 | 08:31 AM
BrewPuBeaver's Avatar
*Big Schpellar*
Originally Posted by FUtec2k
I'm a little confused...if it's overboosting due to the TD04 wastegate not being large enough to expel the necessary exhaust gasses to effectively limit the boost pressure, how would a simple tune fix the problem? Sure a tune will move/remove the fuel cut, but the car will still be overboosting.
In my eyes the only real way to fix the problem is to either port the wastegate on the TD04 of get a larger turbo.
do a little research..... in most cases porting the stock turbo is a waste of time.
there are better way`s to get the desired effect. the flow properties of the air are flowing a lot more quickly because the A/F ratio is leaner, thus making it hotter. ie. hotter air flows faster, reaching boost sooner than normal.
the ECU doesnt know what to do with this, so it just stops sending fuel.
the reflash, cobb, or what ever managmen you decide to go with, will balence out the fuel mappinng and correct the timing. and sort of teach your ECU what to look for, and tell it that making set boost, isnt a bad thing.
Old Feb 5, 2006 | 12:06 PM
DubtecV2's Avatar
...in da hause!!!
Sounded a little hostile...
Anyway, so basically what I said is true in the fact that the pressurized air is doing the same thing, only when tuned properly, the ECU knows what to do with the extra air. That's as I suspected, just wanted to clarify.
Old Feb 5, 2006 | 02:40 PM
  #17 (permalink)
StiGuy's Avatar
4 doors & 6 on the floor
Sounded a little hostile... *snip*
Remember text is a flat medium (i.e. there's no voice inflection).
Brew is hostile but only to US hostiles (he's in the service).
Old Feb 6, 2006 | 05:56 AM
  #18 (permalink)
DubtecV2's Avatar
...in da hause!!!
Hence the reason I simply said that it sounded hostile instead of lashing out
How odd would that be...two guys fighting each other on a forum - and neither of them live close to where the forum is based!
Old Feb 6, 2006 | 06:29 AM
  #19 (permalink)
Franklin's Avatar
Old Feb 6, 2006 | 07:01 AM
  #20 (permalink)
*Big Schpellar*
you AZN ass
