Subaru Tech All We'll Drive
meth injection questions
Old Oct 10, 2005 | 02:32 PM
fat angel's Avatar
Secret Squirrel
i know someone with the smc kit and someone with the aquamist. i would personally choose aquamist but by personal preference. you can turn the setup off as long as you keep a tune for it in the off position. so keep your current tune then get one for the alky.http://www.aquamist.co.uk/rescr/rescr.html
this should answer all your questions.
Old Oct 10, 2005 | 02:35 PM
fat angel's Avatar
Secret Squirrel
Originally Posted by mantra1
No problem. You can run a 50/50 mix alky/h2o but you'll see more benefits from straight alky (better cooling properties if I'm not mistaken). I understand that the SMC kits are back ordered. I'd call SS immediately if you want one now.
you never want to run more than 50/50 mix. it cn be bad. methanol is about 113 octane that's why it is recomended.
Old Oct 10, 2005 | 02:44 PM
mantra1's Avatar
Shaggin' Wagon IV
Yeah, I plan on running straight alcohol anyway.
Old Oct 10, 2005 | 02:46 PM
fat angel's Avatar
Secret Squirrel
Originally Posted by fadedSTi
i need to research some info on the mixing of it. the aquamist can be turned off if you have 2 differentmaps you can switch to
well you wouldnt want to just hook up the alky and let it be. so you would want to have a map for it. so as lang as you had one with out it you could switch back and forth. for methanol you can just pick up windshield washing fluid concentrate. yes i'm serious. it's methanol. i think the guy with aquamist runs about a 30/70 mix. the water does most of the work to lower the temps.
Old Oct 10, 2005 | 02:48 PM
fat angel's Avatar
Secret Squirrel
that will be sweet. running more than 50/50 will increase temperatures rather than decrease. you'd be better running c16. but hey can i have first dibs on parts?
Old Oct 10, 2005 | 02:52 PM
  #18 (permalink)
fat angel's Avatar
Secret Squirrel
i understand i would need a map for the alky but what i meant is if i want to turn it off i need to switch to another map with tune without alky. 30/70 mix, wow figured people would run more. so it just sprays into the intercooler?
yep right into the ic. more than 50/50 increases temps greatly. defeating the purpose of the water. yep right in to the ic, although i've seen it run into the intake.
Old Oct 10, 2005 | 02:55 PM
  #20 (permalink)
fat angel's Avatar
Secret Squirrel
how much is the aquamist kit? how easy are the install on these things? what kind of power do they add? im suremy GREEN would love this stuff
they dont really add power. you can run leaner, more boost , more timing with it due to the lower temps. so you would gain yor power from the tune. the one with the aquamist setup is amazing. when it does kick in it picks up alot of power. but it is rwd.
