meth injection questions
Guest
Posts: n/a
i have a few questions about the meth injection. does it have to be on at all times? do you run certain size jets of meth or is it just a one size nozzle? do you run pure meth or is it diluted with water? thanks for any info
http://www.smcenterprises.com/subaru.htm
Looks like this version is based on boost pressure and as psi rises so does the pressure of alky injection. One of the simpler designs out there. I'm seriously considering this kit to go with my MRT TMIC. Definately bang for the buck.
Guest
Posts: n/a
Guest
Posts: n/a
Just spoke with Scott and their kit is not available. He recommends the SMC version. Very easy to tune (atleast with ECUtek). Order placed!
do you know how the SMC kit works with the questions i asked? for some reason i cant get on that site
It's a progressive spay kit based on boost pressure. The more boost, the more spray. I do not see anywhere on their site about nozzle size.
You can buy pure grain alcohol (recommended) from Home Depot, Lowes, etc., however to keep the whinos from drinking it, they poison it with Methonol.
Yes, the system is always on but is not activated until you reach desired boost.
I just Googled SMC Enterprises and found their site. Lots of good info there. Buick GNX guys have been running these kits for years.
Guest
Posts: n/a
very interested. so alchy/meth are the same things. looks like there isnt a set size it just sprays as boost builds. its is pure alchy or is it mixed with something.
thanks for all the help Rob. ill take care of you next time there is a meet
No problem. You can run a 50/50 mix alky/h2o but you'll see more benefits from straight alky (better cooling properties if I'm not mistaken). I understand that the SMC kits are back ordered. I'd call SS immediately if you want one now.
