Subaru Tech All We'll Drive
changing spark plugs
Old May 22, 2005 | 06:20 PM
JonLGT's Avatar
Just for decoration
take out your airbox, or in your case intake and look on the side of the engine. there are 2 coil packs, take them out and take the plugs out and replace them. Good luck with the drivers side.
Old May 22, 2005 | 06:42 PM
FlatFour's Avatar
Cock Model
I had always believed you were supposed to go one step colder for around ever 100hp over stock.... is this not true? Good luck with the drivers side i could never see them bastards.
02 WRX
K&N, ic hoses, up-pipe & turboback
Old May 22, 2005 | 08:21 PM
davcivic's Avatar
El Mas turboso
I just did mine with my install, they are a PITA like everything else in the car.
Locate you valve covers in your engine, the top cover on the sides of the engine. Running thru the middle of the 2 cams you will see 2 black boxes, these are your coil pack, there is a 12mm bolt holding these in place. Take them out, thenm use a screw driver to pop them out. Get a spark plug socket and go at it. You can use a short extension for your rachet wrench and take them out.
The passenger side has more room to work on than the drivers side. I actually had to push the engine to the passenger side to move it a little to be able to take the coil packs of the drivers side. Not too difficult but you do have to take a few things appart to get to them.
I went with NGK one step colder and got them from Racing zone in Orlando for $19 with tax for the set, so they were like 3.50 each or something like that.
2002 Subaru WRX
1988 Honda Civic Hatch
Old May 23, 2005 | 05:50 AM
  #17 (permalink)
davcivic's Avatar
El Mas turboso
I will have to check when I get home, because I cannot remember right now, but I think it was the same as stock but instead of a 6 they had a 7 in there.
2002 Subaru WRX
Old May 23, 2005 | 07:27 AM
  #19 (permalink)
davcivic's Avatar
El Mas turboso
Yes it is, the car dynoed at 272whp on CFT's Mustang dyno this saturday, I guess around 300whp on a dynojet. I was running still the factory plugs, when I took them out, I pretty much didn't have anything left, 62000+ miles
2002 Subaru WRX
