changing spark plugs
Guest
Posts: n/a
Originally Posted by scoobydoo
There is really no need to change them the stock ones are good to about 60000 miles.
i want to change mine due to i had a boost leak so i know i was running very rich. i want to make sure i didnt ruin any, just to be safe.
Yea what he said The only reason I see to change them is if you plan on running 20+ PSI or if you've been running REALLY rich and may have fouled 1 or 2 or 4
Guest
Posts: n/a
well i meet both then. sorry, only 19psi. but i did have a bad leak and made a few passes at the track so im going to change mine out to be safe. found the NGKs i need for $8.50 a plug. not too bad. now whos down to show me wheres these plugs are at?
I know where they are on the motor but I've never tried to look for them with the motor in the car. If I become unlazy and think about it I MIGHT go outside and check it out
Guest
Posts: n/a
let me know what you find. from what i understand you have to remove the battery, intake, and washer fluid reservior
