Subaru Tech All We'll Drive
wrx clock
Old Dec 11, 2004 | 09:09 AM
SRQSTI's Avatar
Rippin n tearin!
Default wrx clock
how easy is it to take the clock out so i can wire in my radar detector. give details
Old Dec 12, 2004 | 11:22 AM
kickslop's Avatar
noodles
I don't recommend doing it at your clock. The clock is sealed to the dash with sticky double-sided tape (and clips I believe) and you'd be breaking that seal, but that's your call.
A lot of people, including me, have done it at the dome lamp and mounted the detector up near the mirror.
Old Dec 13, 2004 | 07:02 AM
lstepnio's Avatar
1337 H4x0r
The clock pulls right out. There is no double-sided tape and no seal to speak of.
On the other hand I would agree that the better location for the up high. The dome light power source isn't ignition controlled so that would be a hassle as one would need to turn off the radar detector manually. I hardwired mine into the auto-dimming compass mirror wiring harness which is ignition controlled as a hardwire source should be.
I would highly suggest using the auto-dimming mirror wiring harness.
-luke [www.majjix.com]
Old Dec 13, 2004 | 07:13 AM
lstepnio's Avatar
1337 H4x0r
This should give you some tips:
http://www.imagestation.com/album/?id=4292462839
This guy is bit overboard with the new grounding point as the harness already has a ground wire you can easily tap and avoid the while wire brush procedure. That aside it's a good step-by-step guide.
Yes, the harness is there regardless if you have the auto-dimming mirror option.
Old Dec 13, 2004 | 02:01 PM
SRQSTI's Avatar
Rippin n tearin!
i used the clock it was real easy
Car History
97 Civic Hx coupe--Sold
02 Wrx w/usdm Sti swap--Traded in
04 Sti --Sold
96 Civic hatch w/ ITR swap--Sold
90 Civic Wagon B16--Traded
90 4Runner v6 4x4--Sold
08 Civic Lx--Traded in
11 Sti SWP Sedan--Traded in
*11 4Runner Trail Edition 4x4 --DD
*08 FX35 -- DD
Old Dec 14, 2004 | 07:12 AM
lstepnio's Avatar
1337 H4x0r
That also works fine but the radar detector on K and Ka bands is going to most effective mounted up high. If you're worried about laser the detector isn't going to do any good in 99% of all situations anyways and you should look into a laser shifter.
The laser shifters/jammers are very effective on most vehicles installed and used correctly. The setup will set you back $250-$500 bucks. I've had the Escort unit on my wishlist for a while now. The BMW M5 forums also do a groupbuy occasionaly on another well proven unit.
Old Dec 15, 2004 | 06:37 PM
kickslop's Avatar
noodles
I swear mine had foam doublestick tape from the factory. Car was bought new.
Anyway.
