Subaru Tech All We'll Drive
EBC Pads and Rotors?
Old Dec 9, 2003 | 12:43 PM
  #21 (permalink)
CrapBag's Avatar
Mouthhugsarenice
Originally posted by 722ish
I have also heard plenty of people bitch and moan about the 6 pot wilwoods as they arent what they are cracked up to be.. not knocking ya ryan, just repeating what i read, your brakes look the shit at least and hey who wants to stop anyhow?
i have yet to have a problem with my brakes and they stop like no one's business
maybe they just don't like them because they are american
Old Dec 9, 2003 | 12:50 PM
  #22 (permalink)
mofugga's Avatar
who stole my intercooler?
The combination of high performance pads in the front and OEM pads in the back can make a very dangerous rear brake bias on the WRX. I'd honestly stick to the same type of pad in the front/rear on as the Impreza seems to touchy with this. You might not notice this until you're in a emergency situation or in a track enviroment.
already ordered new pads for the rear a couple days ago hawk doesn't make a rear pad tho i autox my nonWRX subaru quite frequently so yeah, that's why the better pads. the rear end doesn't get upset at all with the current setup.
yeah, if you don't ever track the car or drive it real hard there's really no point going with bigger calipers unless you want it too look cool. better pads/fluid/stainless steel brake lines oughta work out nicely, i'd go that route if i were you.
Old Dec 9, 2003 | 02:24 PM
  #25 (permalink)
lstepnio's Avatar
1337 H4x0r
I would say you have yourself a nice little setup picked out that I think you'll be happy with. The one note that i'll add in regards to your selection is that the slotted rotors will be noisey.
I do have a couple of tips based on prior experience with this assuming you're doing the work yourself. If you already have your wallet out I would suggest adding some speed bleeder valves as bleeding the brakes after replacing the brake lines is going to be the most difficult and time consuming part of the job. You need to carefully monitor the brake fluid reservoir and keep it topped off while you are working on the lines and/or bleeding the system as the last thing you want is for the tank to run dry (it's easier than you think to let it run dry and suck in air). You'll need an "flare nut" wrench to break the OEM brake lines loose(you'll have to reseach the correct size, I don't recall off the top of my head). The nuts on the lines are aluminum and will strip like butter with anything less than a flare nut wrench. Lastley I would also suggest some brake noise suppresion goo/fluid to place in between the pad the reused OEM pad backing brackets. I don't know if actually does anything but I used on various pads that where reported to be noisey and never had a peep out of any of them.
One after thought is that if I recall correctly I had to make a slight modification my Goodridge brake lines on the mounting bracket. I don't recall exactly but have dremel tool handy just in case.
-luke [www.majjix.com]
Old Dec 9, 2003 | 04:33 PM
  #27 (permalink)
lstepnio's Avatar
1337 H4x0r
The fluid won't rush out in a unmangagable rate when you remove the lines so as long as you keep the tank full you should fine. I remember using the red protective caps that came with my new lines to cap off the end removed from caliper while I worked on the end attached to the hardline.
Old Dec 9, 2003 | 04:57 PM
  #28 (permalink)
Bone's Avatar
Blingo!?!
Originally posted by lstepnio
If you're actually running in track days the upgrade might be a worth while investment but if I'm not mistaken none of the "regular" Subaru technical forums peeps here participate in track days. Events such as 1/4 mile, Solo-I, Solo-II time trials and the ever famous "I might go one day" really don't justify such an expense. Unless of course you're justifying the purchase with the bling-bling factor which is also fine. Just trying to help you guys spend your money wisley.
hey hey hey I run plenty of sebring days, just not with the WRX yet, need to get new rubber and do something about the breaks myself and or suspension
20TenProductions "Born to lose and Destined to fail!"
Old Dec 9, 2003 | 07:23 PM
  #30 (permalink)
TampaWRX's Avatar
danse
I really do have every intention of getting the car out and flogging it around. I want nothing more than to drive fast cars as fast as they can go. The problem has been circumstances and that this car is still my daily driver. Besides all that, I got a killer deal on the brakes that I was not likely to see again on new parts for a LONG time to come, so I jumped on them and definitely do not regret it in any way, shape or form.
“You will never do anything in this world without courage. It is the greatest quality of the mind next to honor.” - Aristotle (384 BC-322 BC)
Want to know what the war in Iraq is really costing America? Click here
