Subaru Tech All We'll Drive
EBC Pads and Rotors?
Old Dec 9, 2003 | 05:55 AM
M249SAW's Avatar
Firemedic / Local 4420
I hope you are thinking about more than just pads and rotors. I would seriously think about a larger caliper too. Wilwood has some good stuff and Perrin has a 4-pot kit that will fit under the stock WRX wheels.
Old Dec 9, 2003 | 05:59 AM
lstepnio's Avatar
1337 H4x0r
Exclamation
Originally posted by mofugga
i have hawk hps pads on the front & love 'em but they do dust a lot my current brake set up is the hawks up front, OEM pads out back (soon to be replaced with axxis ultimates), stock rotors, & some valvoline brake fluid & they work great!
The combination of high performance pads in the front and OEM pads in the back can make a very dangerous rear brake bias on the WRX. I'd honestly stick to the same type of pad in the front/rear on as the Impreza seems to touchy with this. You might not notice this until you're in a emergency situation or in a track enviroment.
-luke [www.majjix.com]
Old Dec 9, 2003 | 07:25 AM
CrapBag's Avatar
Mouthhugsarenice
wilwood=good stuff i highly recommend
Old Dec 9, 2003 | 07:28 AM
CrapBag's Avatar
Mouthhugsarenice
Originally posted by ZDriver96
They also tested the Subaru with brake upgrade packages in the 2-3 thousand dollar range. They were all just barely better than the stock ones.. The "stoptechs" were the best but still not worth the cash.. "stoptechs" were the cheapest too out of the bunch...
I dont remember the others.
i don't know what kind of brake upgrades these guys are testing but my wilwoods definately far surpass the stock brakes, and i didn't pay anywhere close to $3000
Old Dec 9, 2003 | 08:12 AM
lstepnio's Avatar
1337 H4x0r
They used a upgraded oem brake system in the testing. This meaning pads+fluid upgraded and maybe SS lines.
My experiences mirror the findings of that test. You can think what you want but the upgraded oem brakes in my WRX where as good as the my STi's bling-bling billion-dolla Brembos. The Brembo are a bit easier to modulate but that is due to the pads. I'm sure that the additional mass would have some benefit in extreme track use but that doesn't seem to be the issue here.
Old Dec 9, 2003 | 08:45 AM
TampaWRX's Avatar
danse
Big brake are about consistent braking through better thermal dissipation capabilities. A larger brake rotor and caliper also generates more torque. If I were Billy and not too interested in big brakes, I'd go with the Subaru 4-pots with different pads(will require new wheels ) and a pad improvement in the rear. I run the Prodrive big brakes and love them, though I have yet to get them to a track day. If my coil-overs weren't so damn stiff, the car would probably nose a lot more under braking...I should upgrade the rears, but have lost the motivation to do so lately. Need new computer.
Luke - I have a set of OEM calipers and rotors laying around, if you'd like to trade for your Brembos. I'll even toss in stainless lines and the fluid/pads of your choice.
“You will never do anything in this world without courage. It is the greatest quality of the mind next to honor.” - Aristotle (384 BC-322 BC)
Want to know what the war in Iraq is really costing America? Click here
Old Dec 9, 2003 | 09:01 AM
  #18 (permalink)
lstepnio's Avatar
1337 H4x0r
If you're actually running in track days the upgrade might be a worth while investment but if I'm not mistaken none of the "regular" Subaru technical forums peeps here participate in track days. Events such as 1/4 mile, Solo-I, Solo-II time trials and the ever famous "I might go one day" really don't justify such an expense. Unless of course you're justifying the purchase with the bling-bling factor which is also fine. Just trying to help you guys spend your money wisley.
Old Dec 9, 2003 | 10:20 AM
  #19 (permalink)
722ish's Avatar
ASM FTW!
I have read that the Stop Tech Kit is better than all the other big brake kits, as it showed less heat fade, shorter repeatable stopping distances and better modulation than all the other big ass kits out there. I have also heard plenty of people bitch and moan about the 6 pot wilwoods as they arent what they are cracked up to be.. not knocking ya ryan, just repeating what i read, your brakes look the shit at least and hey who wants to stop anyhow? Nevertheless, my car has had different pads on the front and rear a few times now, and i have never had any problems, however, i may not drive them in ways you did, so i am not able to see any problem? Is it autocross stuff that screws them up? If so, im not always into stuff like that, but fast sweeping stuff, and a little trail braking, and i never have a problem...
95 Supra Turbo 6 speed
11 SWP STI sedan
Old Dec 9, 2003 | 12:42 PM
  #20 (permalink)
CrapBag's Avatar
Mouthhugsarenice
no i was talking about what zdriver96 was talking about, the $2000-$3000 brake upgrade
