Subaru Tech All We'll Drive
Please Help
Old Oct 14, 2003 | 07:14 AM
P V's Avatar
P V
333HP N/A 6 Cylinder
Default Please Help
I have a 02 WRX with only a CAI and BOV. Inotice a drop in preformance so I took it to Mastro they said the ECU was seeing the right boost. That was it from them and they charged me 40 bucks to tell me it is ok, it's still under warenty. So bought a boost gauge and no mater where I put it (off the BOV hose, off the manifold, off the turbo) it never reads higher than 7 PSI. I think it maybe the factory boost soleniod? Any Ideas? Thanks Paul
Old Oct 14, 2003 | 08:23 AM
P V's Avatar
P V
Billy thats were I took one of the readings from and it came out 7psi
Old Oct 14, 2003 | 08:32 AM
Tripw0l's Avatar
The thirst mutilator
You sure you didn't fuck up your BOV CAI install?
"If I could write off your murder
I'd save all of my receipts
because I'd rather you be dead
than lose a tiny shred of what I made this fiscal year"
-Nathan Explosion (Brendon Small)
Old Oct 14, 2003 | 09:11 AM
2TurboImports's Avatar
sooo...where's the turbo?
i think someone may have gotten the shitty GFB bov that has been known to leak and be shitty....
Old Oct 14, 2003 | 09:18 AM
P V's Avatar
P V
Nothing was messed up on the install it run fine with the set up for 15k miles. just happened all of the sudden. Is there any way to test the boost seloniod ( subaru calls it a duty valve) or does anybody have one lieing around from when they took out there OEM for a aftermarket boost controller. Thanks for the help.
Old Oct 14, 2003 | 09:31 AM
M249SAW's Avatar
Firemedic / Local 4420
Those "shitty GFB BOV" has handled a car running 30psi of boost. Most of the time its people spraying WD40 into the valve and wondering why its gunked up.
Old Oct 14, 2003 | 02:33 PM
P V's Avatar
P V
up
Old Oct 14, 2003 | 03:06 PM
marksaccord95's Avatar
TR Registered Member #5
put some soapy water around where the BOV mounts to the IC and rev the motor manually from under the hood, see if its bubbling up, that means the gasket at the bov is bad. but also the factory boost solenoid only alows you to see full boost in 3rd-4th gear.
http://www.floridaracing.org
Old Oct 14, 2003 | 06:46 PM
blackwagon's Avatar
"color blind kid"
Did you play with any boost lines? Missing any resistors... I ran on 7psi once... im to lazy to order new boost lines so I put my mbc back on...
EGT Limp mode gives you 7psi but you would see a cel also with it.
Learn how to use the feedback system! When people don't fallow through with a deal, fucking make it known! of course everyone has all positive points, no one fucking gives negatives for flakers, if you start giving negative feedbacks for flaking maybe people on tr will stop making stupid ass posts about wanting to buy shit then not showing up for the shit.
