The Projects Watch out in this hood ! Current And Past Ford Project Topics Only.
My 85 Coupe Project.....
Old Mar 25, 2010 | 06:42 PM
  #471 (permalink)
GNs-r-slow's Avatar
Bondsman
Damn....hate to hear it!
Old Mar 26, 2010 | 12:05 PM
  #472 (permalink)
KAILUAZ's Avatar
Infidel
Man that engine sounds haunted!!
Old Mar 26, 2010 | 09:53 PM
  #473 (permalink)
GNs-r-slow's Avatar
Bondsman
I have a spare early 351W block and crank
Old Mar 27, 2010 | 11:14 AM
  #474 (permalink)
franktf's Avatar
I may be interested, just depends on what I decide too do.....
It's definately lifting the head surface..... I got the head gasket off the pass side and #4 stretched the gasket almost into the water port, looks almost like a nitrous backfire..... Still no signs of detonation in the chamber or on top of the piston atleast on this side, it must be getting water in the cyl and causing more of a knock rather then detonation????? I also threw the head studs away, the have already been torqued down 5 times and I just don't trust them anymore.....
I'll pull the other side tomorrow and see what it looks like but in the meantime here's a couple pic's of this gasket.....
Old Mar 27, 2010 | 11:45 AM
  #475 (permalink)
DrDirt's Avatar
Team Geritol Racing
I reiterate...Spencer's Termi setup.
Sorry about the bad luck, Frank.
YO! Barry! You LOST!
Old Mar 27, 2010 | 01:18 PM
  #476 (permalink)
franktf's Avatar
It's hard to believe that you can't push these E7's much past 6.50 at 107.5 in the 1/8th without these kind of issues.....
Old Mar 27, 2010 | 01:44 PM
  #477 (permalink)
GNs-r-slow's Avatar
Bondsman
Cometics?
Old Mar 27, 2010 | 03:16 PM
  #478 (permalink)
Hurstmeister's Avatar
What about gong back to MLS gaskets?
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Mar 27, 2010 | 03:31 PM
  #479 (permalink)
Iraq&Roll's Avatar
The thin decks on the oem iron heads suck. Seems once they lift, they will never seal. Decking them only makes it worse.
General Stonewall Jackson has been quoted saying that when the time of war comes,
“My advice is to draw the sword and throw away the scabbard".
Old Mar 27, 2010 | 04:11 PM
  #480 (permalink)
franktf's Avatar
I agree 100%, I think the 60 plus passes I made when it was all stock weekened them and every time I have bolted them down since they have only gotten worse..... When they were surfaced they only took .005 to .006 but I think that only made them worse.....
I think they would probably be ok for someones mild application, but definately not for any boost or nos.....
As far as Cometics or any other MLS will not help at this point..... The Cometics I just had on right after the surfaces were cut were slowly leaking and getting worse.....
