My 85 Coupe Project.....
Went a new best of 7.017 @ just over 100mph in the 1/8th at Sunshine last nite even though it was misrable hot out..... I have made no more changes yet other then just varing the leave rpm.....
First thing I need to do now is get the brakes working better..... I tore some of it apart this morning, so I can make some changes.....
TurboRAM Member #5
24psi & Stable
GET SOME
I like it, very easy to use..... I am able to run 20deg at idle, it advances to 40deg from 1000 to 2000, and then it pulls 20deg by 12.5psi.....
The best part is it has infinate adjustability, you can do almost anything to the timing with the use of a map sensor..... and it has a built in 3 step.....
I don't think it can be beat for the price.....
