air-to-water Intercooler setup
Originally posted by Force Fed 23
I forgot the exact number, but I believe water can take over 200 times the amount of heat out that air can.
even better then water is chilled alcohol, or antifreze this is for when you want freezing air temps on even 100+ temp days
Unfortunately once that water's hot, its hard to get the heat out of it by transfering it into the air.
Stock w/a IC systems (syclone came with em) work fairly well, especially to solve charge pipe plubming issues. We just use a 2nd radiator (cche) to cool off the water.
They shine for drag racing because its easy to make them ice cold. Where they loose out is the hotlap, daily driving arena. Choose what you want.
Either way, you cant get colder then ambient w/o an exhaustable cooling source. (with exception of an 'intracooler' that uses w/a and cools the water with the a/c system's compressed freon)
Ian
Syclone | CRX si | Mazda3
Ian
don't go cheap on the heat exchanger and pump if your doing alot of street driving, and don't fall for the pressure over volume thing on the pump. the more the water moves the better.
www.coastaldyno.com
Smackin down LS1s since 99', LQ4s too...
www.coastaldyno.com
