Sponsored by: CARiD
Difference in wastegates?
Old Apr 2, 2003 | 02:38 PM
buck19's Avatar
Forever Broke Nissan
Default Difference in wastegates?
whats the difference between the tial and delta wate gates?
which is better?
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Apr 2, 2003 | 02:49 PM
PoppaSmurf's Avatar
Chowdah-head
tial, by far
Poppa J. Smurf
Old Apr 3, 2003 | 07:11 AM
ComatoseSedan's Avatar
Fo Shizzle My Nizzle
deltagates are like beginners wastegates
'88 Civic Sedan - Cardinal Metalic Red
153.5 whp AllMotor
www.LHTperformance.net
Old Apr 3, 2003 | 09:11 AM
buck19's Avatar
how is it a beginners. i guess ill get a tial. do they make one for the ranges of 9psi to about 20psi?
Old Apr 3, 2003 | 09:52 AM
I just say that because EVERY freak'n turbo kit you buy is going to come with a deltagate.
153.5 whp AllMotor
Old Apr 3, 2003 | 11:06 AM
PoppaSmurf's Avatar
Chowdah-head
the wastegate should come w/ springs to cater to what boost you want it open at
Poppa J. Smurf
Old Apr 3, 2003 | 01:00 PM
buck19's Avatar
so i would have to change the springs when i go to the track
Old Apr 3, 2003 | 01:24 PM
PoppaSmurf's Avatar
Chowdah-head
nope, spring only sets your base boost pressure, you can use a boost controller to alter the actual amount you run, the spring will represent the minimum boost you can run
Poppa J. Smurf
