Sponsored by: CARiD
Any FI guru's have views on this?
Old Jan 21, 2003 | 11:08 PM
  #31 (permalink)
0HP930's Avatar
Guest
Hell, I think your problem along with a few other people here is wanting too much from too little.
One of the rules they taught me at my family's shop is that anything more than 2HP/CuIn is going to be trouble. A lot of people here are verifying that fact so I'm planning on keeping it concervative.
I will be happy just to get 400 HP at the back wheels, whereas it only had 400 at the crank when I bought it. Just in case though I will be adding a large enough supplemental injector to take me up to the low 500s if the cams and head work will easily allow it.
That will not be too much of a push for 3.3 L. I can't afford to break my crank or engine cases, but everything else ie pretty much expendable.
With all that and a lower gear I hope that the 1/4 mile time should become very respectable. With most of my weight on the back wheels it should be interesting.
Old Jan 22, 2003 | 03:39 AM
  #32 (permalink)
Levi's Avatar
Originally posted by "Mr Self Destruct"
Originally Posted by Levi
You really need to lean that bitch down a bit.
Matt your just too stupid for words to describe you...
And everyone claims you know something, you know nothing..Ricer tool.
Whether or not he drives a rice car means nothing for the fact that he is 100% correct : 14:1 is LEAN, not rich, for a f/i car. Are you going to argue that?
What I am trying to say is, if he get the ratio down to 12 to 1 it will make more power..unless Turbo Hondas are different.
custom parts is our perfection.
Old Jan 22, 2003 | 05:37 AM
  #33 (permalink)
Matt Vassallo's Avatar
lifelong learner
but you said lean it out. hjow will leaning it out get it to 12:1 levi /
you lose again.
porsch guy.
i got sick of replacing shit from the flywheel back. i'm upgrading my drivetrain.
rest in peace tim.
Old Jan 22, 2003 | 05:54 AM
  #34 (permalink)
Levi's Avatar
Its clear to me that you just like to argue..but it should run better with a 12 to 1 ratio.
Instead of reading the whole post I wrote, you only noticed I made a mistake with using that word, but its clear I know where max power can be made.
Just take a break...
