Any FI guru's have views on this?
Guest
Posts: n/a
He meant to say rich Im sure. Read the rest of his sentance and you'll understand the mistake.
I was perty happy with that setup. Just wish I woulda got my injectors BEFORE the motor blew.... damned Eclipses!
Shoulda been watching my boost guage... *shakes head*
Guest
Posts: n/a
Um, 14:1 15 L34|\| my f|213|\|d5.
|23m3mb3|2, 175 p4|275 0f 41|2 70 0|\|3 p4|27 fu3l. 50 14:1 \^/0uld b3 14 p4|275 0f 41|2 70 1 p4|27 0f fu3l. 0p71m4l 41|2/fu3l 0|\| m057 m1ldly b00573d 57|2337 537up5 \^/0uld b3 12-12.5:1 4/f. 14:1 15 4 5m1dg3 l34|\| f0|2 |\|/4 m070|25 \^/17h m1ld c0mp|235510|\|!
Actually, if my memory serves me correctly 14:1 is the perfect stoichiometric ratio for air fuel combustion.
This is also the ratio that will give you the most power per quantity of fuel assuming you can use this ratio without detonation.
The only reason to go any lower is to reduce the risk of detonation in high compression or forced induction motors.
For that reason I would say it is not lean, but just not rich enough for use under adverse conditions.
If your view of mild compression is less than 10:1 that a/f ratio would be just fine for a n/a motor and should be pretty close to what all modern closed loop emissions motors are trying to keep their mix rate at.
Guest
Posts: n/a
:l0l: y0u'|23 k1dd1|\|g |21gh7? 5701ch 1|\| \^/h47 c0|\|d1710|\|5? \^/h1l3 17'5 7|2u3 7h47 14.7:1 15 c0|\|51d3|23d 5701ch, 7h475 50 v3|2y m15l34d1|\|g. 7h47'5 4 \^/0|\|d3|2ful |24710 70 |2u|\| f0|2 l1gh7 c|2u151|\|g 4|\|d 1dl1|\|g c0|\|d1710|\|5, bu7 f0|2 p0\^/3|2, 17'5 4b0u7 \^/0|27hl355. |2u|\| 4 b00573d c4|2 47 7h47 |24710 u|\|d3|2 l04d, |\|0 m4773|2 7h3 c0mp|235510|\|, 17'5 f4|2 700 l34|\|. 4|\|y 7u|\|3|2 \^/0|27h h15 54l7 \^/1ll 73ll y0u 7h47, 4|\|d p34k p0\^/3|2 15 u5u4lly 47741|\|3d 47 |247105 4|20u|\|d 12:1 \^/17h |23l14b1l17y 1|\| m1|\|d 0|\| 93 0c74|\|3 g45. 0|\| h1gh 7357, y0u c4|\| |2u|\| l34|\|3|2 4/f, 4|20u|\|d 13-13.5:1, 1|\| |24|23 c4535 l34|\|3|2 7h4|\| 7h47. 0|\| |\|/4 m070|25, \^/h1ch bu1l7 7h353 d4y5 7yp1c4lly h4v3 4 c0mp|235510|\| |24710 0f 4|20u|\|d 10:1, p34k p0\^/3|2 \^/1ll b3 f0u|\|d 4|20u|\|d 13.4-13.6:1, 0bv10u5ly |21ch3|2 45 c0mp|235510|\| g035 h1gh3|2.
Wow, you just proved that you really don't have too much field experience, if you know what I mean with tuning performance engines. Books are great, but test some of the theories a little.
14+:1 will work great on high compression motors and boosted motors under low throttle, low load circumstances, but that is it. The burn would be WAY to hot under WOT causing extreme detonation and burning of the pistons and or valves.
