Sponsored by: CARiD
Solenoid Boost Valve Alternatives
Old Sep 24, 2002 | 08:19 AM
SLAAB's Avatar
Originally posted by "Greaser"
ah, this is not a bleeder type !to my knowledge! it is a one in and one out. However it does have a third nipple with a foam filter i forsee that this is a simple solenoid used for several possible functions......GM likes to do that.
I have some at home i can take a pic of. i'm stupified by the "bleeder type" you mention
on my drag car i use the old school blitz unit, would you classify that as a bleeder type(i guess i would since it lies to the vacuum assisted spring to adjust boost) with this in mind i dont know what kind of solenoid you will find that is not a bleed type , thats what controls boost pressure from a wastegate is pressure/vacuum on the actuator. unless its a variable vane controller or some shoot
Thanks meng!
You are the only one that understood what I'm looking for. I'll try a swap with a later mod year and see if that improves things.
