Flaring Direct port tubing
Well im in the middle of installing a NX kit on my z6 and I realzide that NX dosent use compression fitting's on the distribution block end so im gonna have to flare the tubing. I managed to find some metal brake line tubes around my house that bend like butter compared to the nx stainless tubes, and because this is on a soch I dont have much room at all. You all know that brake lines already have 2 flared ends on each peice, well they are the same size as the nx lines and the flare works perfect so im using them, but im gonna have to flare the end that go's into the dist block. Dose a certain company make a tool that dose this, or will I have to cut all the lines to size then take it some where to be flared? Any help would be apreciated.
Ryan
Ryan
) at pretty much any auto parts store. They should have em along with brake line parts and such. If all else fails, go to napa, they should definitely have one.
