Sponsored by: CARiD
boost vs compression?
Old Aug 28, 2002 | 07:32 PM
aimisgoop's Avatar
Cracka-Faced Cracka!
Default boost vs compression?
boost in form of turbo/supercharger likes lower compression and boost in form of n20 likes higher compression, right?
AIM: AIMisGOOP
Originally Posted by moldyhands
in the immortal words of the very wise Kid Rock, "3 foot tall with a 10 foot dick"
though for me, you'd have to change it to 10 inches, and you'd have to change inches to millimeters, and you'd have to change 10 to 5 and you'd have to change dick to poor excuse for one.
Old Aug 28, 2002 | 07:33 PM
Hondahunter97GT's Avatar
Red Stripe Beer!
no
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
Old Aug 28, 2002 | 07:42 PM
aimisgoop's Avatar
damn u and ur whorey self!!!
AIM: AIMisGOOP
Old Aug 30, 2002 | 07:27 PM
0HP930's Avatar
Guest
I know you are right on the turbo assumption but I will leave it up to a nitro expert to chime in on the nawwssss.
Old Aug 31, 2002 | 09:33 AM
HybridSS's Avatar
I have fuzzy eyebrows
The only reason you can run high compression with n20 is the extremely cold temps of the the intake charge. If you had an intercooller capable of dropping the intake charge to 0 degrees you could run alot more boost on higher compression too, not that you want to...it would still be better to keep compression lower and just up the boost, but you get the point. Alot of purpose built nitrous motors run lower compression...you can run more nitrous that way before having to up the octane. But more often than not...people who use nitrous like to run good on motor as well..so they opt for the added benifits of a higher compression motor= More HP NA. Thats the way I am going now.
You know we are really talking dynamic compression here and not static.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
