want to put an aftermarket BOV..
Some of them are vacuum operated.
Internet search for one that has tech info and they will tell you how it works..................if they want to sell it.-Bob
But are you planning to put a blow off valve on a car that does not have a turbo?
If it was turbo'd what happened to the stock valve?
If I'm not mistaken, you have a CBV not a BOV on your turbo. You can still install a BOV but to get the desired effect, you'll need a CBV blanking plate ( Quickbrick Motorsports CBV Blanking Plate ) and the BOV and whatever flange/pipe to connect it inline with your charge pipes. VivaPerformance sells an entire kit, Blanking plate, silicone vaccum hose, and a Forge BOV. They also sell a coupler that replaces the factory coupler coming off the intercooler and has a T-fitting that the BOV mounts to so you dont need to have a flange welded to your charge pipes. Here's a link: VIVA PERFORMANCE || Blow Off Valve Kits
Jeff W.
1998 Volvo S70 GLT
Top End Performance
"If You Can't Race It Or Take It To Bed, It Ain't Worth Having."
Jeff W.
1998 Volvo S70 GLT
Top End Performance
