Sponsored by: CARiD
D series turbo, what do you think????
Old Aug 12, 2004 | 10:51 PM
jhatch10's Avatar
EKuadorian
Default D series turbo, what do you think????
I have a 96 DX civic hatch with the stock D 16 non v tehc with 130xxx miles
Im going turbo, this what im planning to do before i throw on the turbo:
stage 1 ACT clutch
2000 EX manifold
AEM fuel rail and regulator with RC injectors (3?? dont know which ones)
Cometic head gasket
JE rings
and im shot peening(dont think i spelled it right) the rods
(im doubful if i should wait and get JE pistons but i dont have much money)
MSD ignition distributor cap and already have MSD conductor 8.5mm wires
a Skunk2 camgear
This is the turbo that im piecing 2gether
I already have a T3/T4 turbo mint no shaft play or nothing,
a custom turbo manifold, downpipe.
What im planning to get is custom piping and a $250 FMIC from Ebay, Greddy Type S bov, Greddy turbo timer and boost controler,
tial wastegate and all the other things.
Let me know what you guys think. Any comments,suggestions, are welcome. I plan to boost 7-8 psi at daily driving, I dont race that much but when I do i was thinking boostin 10 psi at the most. Do you guys think thats safe? Im not a mechanic or have a lot of knowledge about forced induction or engines, This my first project and my friends that knows a whole lot more than me are going to help me and ill try to learn more. Do you guys think its safe because of the engines age and milage?
Old Aug 13, 2004 | 09:04 AM
jhatch10's Avatar
EKuadorian
Thanks for all the info cronic
Old Aug 13, 2004 | 04:12 PM
95Ride's Avatar
Gangsta What
first (not to sound like im ragging on civics or SOHC's) i say you use your money to buy a motor swap or atleast a vtec head....but just in case you like the thought of having a turboed SOHC....
+1 on the stage 1 clutch if your going to upgrade atleast get a stage 2 the stage ones are usless and its not that much more
also +! on the aem fuel rail....and id go with 450cc injectors and maybe a 255 fuel pump depending on how serious you are about this....
msd ignitions arnt really worth the money unless you a have a full ignition system but the wire upgrades should help and id get atlest 2 prong plugs...
and if you really plan on slapping a T3/T4 with boost controller onto a SOHC i would get all new fordge internals and check the internal walls for cracking or hard wear and possibly get the block hooned
+ i think a T3/T4 puts out up to 20psi if not more if im not mistaken so if you want to run 8psi dailly driving just get an 8psi waste gate and use the $250 for the boost controller on something else
if your going to add a pulley you might want to think about a new cam.
and as for the FMIC a mitsubishi side mount might actually be more efficient that a cheap generic frount mount and coast you a hell of a lot less (that is unless your getting a brand name one for that price)
and you might want to consider upgradding the valve system i dont think stock d16's are made to handle a lot of HP
once again sorry if it sems like im being hard on your plans its just that i believe in doing something right if your going to do it all...plus id hate to see a post where you need something cause it blewup....but good luck id love to hear how it goes when your done...or some pics would be cool
Old Aug 14, 2004 | 07:45 AM
jhatch10's Avatar
EKuadorian
thanks for the info 95ride
Old Aug 14, 2004 | 08:15 AM
jhatch10's Avatar
EKuadorian
I plan to put a skunk2 cam after sometime. I dont believe a vtec head is gonna make that much a diference with boost
Old Aug 14, 2004 | 09:49 PM
95Ride's Avatar
Gangsta What
true ive just only seen one SOHC that really made me go DAMN and that was bananna's but it wasnt really a factory 1.6 he bored it out and everything and lots of money but who knows yours might be the second....let mekknow how it goes
Old Aug 15, 2004 | 08:01 AM
RyanCivic2000's Avatar
Fuck the DOHC
Originally posted by Cronic
You've not been around for serious single cams then.
Yeah there's definately a BUNCH of them popping up in the last year or so. I just found out about TurbodCX on Honda-Tech hitting 11's on street tires with his D16 and Matt Patrick of ZEX made over 600whp with his D16 this year.
On topic, I definately agree with everyone else about getting the forged internals. If you're taking apart the block you might as well put them in. A T3/T4 is capable of quite a bit of power, get the internals and have a setup capable of 400whp, don't get them and have a setup good for no more than 200whp. You will want more power later, trust me.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
