Sponsored by: CARiD
air to air/ air to water
Old May 27, 2004 | 02:20 PM
kender's Avatar
gadget man
Default air to air/ air to water
what are the pros and cons between the air to air intercoolers ( fmic ) and the air to water.
obviously the differences in hooking up the plumbing and trying to tap the right place for coolant on the air/water and a shorter charge pipe length, but I am wondering more on the performance side.
does the air/water give as much of a temp drop?
does the engine coolant system run hotter and would upgrades to the cooling system help counter act that?
would the air/water be able to support higher hp later or is the air/air better for higher hp?
U.S.S.A Crew Member #001
Old May 27, 2004 | 03:20 PM
pressuredsol's Avatar
Pleasure the do me
Air/water is the way to go imo. However, I have had conversations with people, and air/water is not the best idea for daily driver. The systems that I have looked at are independent, having their own pump and water/coolant supply. There was someone on TR that had a system for sale a while back. I would search for it.
Old May 27, 2004 | 04:46 PM
kender's Avatar
gadget man
why is air/water not good for a daily driver?
Old May 27, 2004 | 05:24 PM
NChatch's Avatar
i stepped on my weiner!
you could be really cool and use both!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old May 27, 2004 | 09:24 PM
0HP930's Avatar
Guest
You appear to be confused about the nature of a water to air intercooler.
These systems use their own water and heat exchanger, not your regular engine coolant.
Old May 27, 2004 | 11:53 PM
China's Avatar
Communist
probably be a bit more expensive and a lot less economical in terms of daily drivers. if it were air to air, lot less parts to worry about. the only thing may be hose poping off versus something burning out.
china
Old May 28, 2004 | 02:25 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
Do a search on this and see what comes up... I remember sometime last year there was a long discussion about this that went on forever...... Maybe if I get bored later I'll do the search and post the link....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old May 28, 2004 | 02:26 AM
Retired Ricer...
https://www.tamparacing.com/forums/s...er+intercooler
I was bored
Old May 28, 2004 | 02:18 PM
kender's Avatar
gadget man
Thanks guys I looked at some a/w ic kits on the net and the price is a real turn off, that and the complexity. I think I'll stick to air/air.
Old May 29, 2004 | 01:53 AM
Retired Ricer...
good call...
