Manifold Gasket
My SVO came with no head to turbo manifold gasket from the factory. The previous owner had his turbo rebuilt, and the shop put a gasket on the car. This gasket is now leaking (as do most SVO's with gaskets after 5-10k miles).
Dave (ForceFed23) recommended copper RTV as he and his turbo 2.3 gurus have had great luck with the stuff. There is also a copper gasket available through an aftermarket supplier. Do these actually hold under the high heat and pressure? What does everyone here use?
Does the car have an aluminum or iron head? Yes I am retarded and didn't think to look. I'd also look into some stage 8 bolts like the old siver car had to make sure that crap doesn't come loose regardless of what the head is made of.
don't use the gasket. The head is iron and the manifold is cast iron. As long as the surfaces are flat and true, you won't have a problem sealing. For all your turbo 2.3 needs, visit www.turboford.org
1989 SHO
1987 Merkur XR4Ti
1989 SHO
1987 Merkur XR4Ti
Guest
Posts: n/a
I don't know of anyone using anything but the stock bolts with no issues.
