Sponsored by: CARiD
Manifold Gasket
Old Jan 15, 2004 | 04:35 PM
Alan's Avatar
drives euro trash
Originally posted by drag0n
what all is done to your SVO? I myself own a XR with a few things done to it.
Right now it is pretty much stock. Previous owner had the turbo rebuilt and the installer put a larger compressor wheel in it (not sure of size). He also eliminated the cat and installed a manual boost control.
Craig and I just finished installing the new injectors. Craig also torqued down my manifold bolts, noting they were one step less than "hand tight". So that fixed about 80% of the exhaust leak. So now with no fuel leak, less of an exhaust leak, and the TB spring fixed the car feels a bit more spritely. It will actually start burning the tires around 4500rpm while accelerating through first gear. Much better than its lethargic self when I first purchased her.
Old Jan 16, 2004 | 09:57 AM
Alan's Avatar
drives euro trash
Originally posted by Force Fed 23
Alan, tried sending you a PM but your box was full. Rob put a TO4 50 trim wheel in an otherwise stock turbo.
I'm still learning turbo tech. Is this a good or a bad thing?
Old Jan 16, 2004 | 10:24 AM
drag0n's Avatar
<---has a V-trim wheel in a stock T3 housing
1989 SHO
1987 Merkur XR4Ti
