BOV questions
TurboXS RFL is loudest
Beef up the bottom end...and consider headstuds from ARP...or you will be watching your heads float like fairies.
a BOV has a flange. just weld an identical flange to your intake piping..any bov fits any application. it also has a line that runs to the intake manifold that lets out air while there is vacuum in the intake manifold. (your still pumping exhaust gas out, so the turbo is still spooling, it needs somewhere to go since the throttle blade is pretty much shut) and in an automatic, yes, itll only blow off when you let off the pedal and the throttle blade shuts.
some people will run dual BOV's if they are flowing alot of air, and 1 BOV isnt adequate to vent the excess air out.
PS...no they dont sound diff on a v8 or i4, they sound different in reference to how much air the turbos are pushing
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
itll go "off" when the intake manifold vacuum holds it open, when the spring can no longer hold the boost levels seen inside the intake piping, and when the throttle plate is closed and there is a immediate building of intake piping pressure.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Originally posted by drag0n
I can vouch for the turbo xs RFL (yes Im a wanna be ricer). Ive been running one on my XR @ 20psi and Ive scared little old ladies with it.
atmosphere venting will cause a car to stall if the air it is blowing off has already been counted by the MAF because the computer has already accounted for it, added the required fuel, then it kinda just disappears, so your left with a very rich state and possible stall or sputtering
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
What everyone else said. I have seen the TurboXS RFL. The quality didn't look too good. Anyone who has used and/or seen the blowoff valve might agree with me. I like TiAL blowoff valves. I have heard a couple on Honda's and one in an SR20DET (Vapor's). They both made different sounds. I describe Vapor's as "Satan in his engine bay" and the TiAL in the Honda as "a quite blowoff valve". Here is my old TiAL blowoff valve. It's in Taylor Durdan's possesion now.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
Originally posted by InsaneCivicSedan
still man save yourself some trouble later and beef up the internals in that mofo....
all we are waiting on is which size we should go with....
Fear The Hood
or Fear Whats Under it
02 Trans Am WS6 with Basic Bolt Ons
Anti-Venom Proformance
Eye Candy Paint and Body
"2002 The Last of the Breed"
Fear The Hood
