boost calculations
Guest
Posts: n/a
Originally posted by PoppaSmurf
it wasn't directed toward you, although i had to throw the cutout comment in there just for funny, lol, but 280 whp is HARD to get out of a 14B
smurf? slip? NAAAAAAA....chunk is always right
280whp is hard enough to get out of a DSM let alone a 14b..
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Guest
Posts: n/a
Source: http://www.stealth316.com/2-3s-compflowmaps.htm
TD05H-14B. This stock turbo from 1st generation 2.0 L single-turbo DSM cars has excellent coverage of demand lines for the 3000GT/Stealth 3.0 L twin-turbo modified engines. At 7000 RPM 450 cfm effective VAF should be attainable with 25 psi boost. At 8000 RPM, almost 500 cfm should be available. A different exhaust manifold is required for the TD05H turbine.
Now if we take this as truth, 8Krpm - 500cfm
if we take 500cfm/144 (cfm to lbs/min conversion) we get 34,7 now we know that the lbs/min conversion to bhp is nearly 10*lbs/min so we use that generally, we get 347bhp so we take 20% of that and we get 69.4, we subtract 69.4 from 347 and we get 277.6
Not too far off from 280whp is it??
Guest
Posts: n/a
...that would be hunky dorey...if dsm's could spin 8k...but a small 16G flows like 505cfm@15psi...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
try without the decimals.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Guest
Posts: n/a
Guest
Posts: n/a
7h3|23 15 |\|0 b0057 = hp 3qu4710|\|. 17 \^/0uld d3p3|\|d up0|\| 50 m4|\|y 07h3|2 f4c70|25, l1k3 1|\|73|2c00l3|2 3ff1c13|\|cy, c4m 3ff1c13|\|cy, 3><h4u57 4|\|d 1|\|74k3 3ff1c13|\|cy, |\|07 70 m3|\|710|\| 7h3 7u|2b0'5 3ff1c13|\|cy 47 7h47 c0mp|23550|2 |2pm. 45 4 g3|\|3|24l gu1d3, y0u c4|\| 54y 1p51 15 u5u4lly 3qu1v1l3|\|7 70 +10hp 1f 7h3 c0mp|23550|2 15 1|\| 17'5 3ff1c13|\|cy |24|\|g3. 4|\|y7h1|\|g 3l53 15 |\|07 |234l \^/0|2ld c0|\|d1710|\|5, bu7 1d34l c0|\|d1710|\|5, 13, 50m37h1|\|g 7h47 4lm057 |\|3v3|2 h4pp3|\|5
