How much Hp can I pull with this!
Heres my setup. I have an LS. Stock short block, turbo head gasket, built ls head fully ported & polished, stage 2 cams, and dsm 450 injectors. My turbo kit consist of a Garrett T3/T4 62-1 with P-trim wheel thats been clipped, Tial 40mm wastegate, Tial 50mm BOV. My fuel managment right now is an SAFC and 450cc along with the AVC-R that I havnt installed yet. I was wondering how much boost I could run on these injectors, and also what do you think is the most I can put down on the stock bottm end? I am only running 5psi right now and it spins quit a bit when I throw third so I know this car has potential, I just wanna know how much the stock bottom end can take.
P.S. I am building my other short block now so I really dont care much for this one
-Tony Moore (Moorespeed12@yahoo.com)
Guest
Posts: n/a
See sig. Call number after 2pm tomorrow.
Get this setup tuned. Your good for 250ish w/o stand alone.
62-1 is a bit large, and doesn't flow much more then a 60-1, 14psi is probably where your going to make out that bottom end. ONLY WITH TUNING will you be able to achieve this.
Are you saying that the injectors will only let me go up to 250? I still have the AVC-R, helix throttle body spacer, STR manifold, JE 9.0:1's and some eagle H bheams sittin in my garage waiting to get put on.
Cronic: Yes I know my turbo is a bit large. I was suprised when I got it. It has a Turbonetics intake side and a Garrett exhaust side. He said the way the turbo is setup, it can make 650hp. At least I wont have to upgrade my turbo anytime soon. And yes, as soon as I get everything put on I will bring it down there to get tuned. My goal is to be the first person around here to hit or get damn close to 11's on a bone stock bottom end.
The guy I bought it from had it on an B16 and was making 428hp @ the wheels. I will try to find his dyno sheet. He's doing a GSR now thats stroked out to an 2.2 or 2.3 (not sure) fully built with a T72, and no Im not talking about cheesefrog.
Sorry man.
